tubes...
Started by CJ, October 24, 2007, 02:29:10 AM
CJ
Quote from: HEAVIER THAN HELL
Quote from: callme.nastywell i thought you were saying the ecc81's for the PI and two JJ6L6's for the power tubes... right? because the PI tube is way smaller than the power tubes so you couldn't interchange them anyway.
that IS what I'm saying.
:twisted:
ok, just checking. and i'm correct that the PI tube is the really small one right?
Elliot
Yes that's right - the phase inverter tube is the small one and the power tubes are the big ones.  If the power tubes are 2 years old a change would probably add some presence and brightness to the amp.
CJ
Elliot
That would work fine - you don't need matched pairs for the PI tube (the 12A*7) - only the power tubes.
CJ
alright, last night i went and played on my amp again, and this time i cranked it up a bit. definitely sounds much better and doesn't sound dark at all. Maybe my amp just sounds kind of dark when the volumes low. i still bought a new PI tube off ebay though since it was only 14 bucks shipped.
