Started by AdamB, November 26, 2007, 12:14:11 PM
Quote from: TomWI'm thinking about replacing the volume pots in my sg to 500k as well. Will I need the standard ones or the 3/4" shaft ones?
Quote from: Fourth FelineQuote from: TomWI'm thinking about replacing the volume pots in my sg to 500k as well. Will I need the standard ones or the 3/4" shaft ones?Standard Tom, the 3/4" are for capped top / Les Paul type guitars. I made the change in my S.G. - and the amount of wood between the top of the pot and where the bottom of the control knob needed to go was relatively slender. Of course it is not as thin as a Strat or Tele control plate, but on those you have to use the locking nut under the plate to lower the pot a bit deeper into the cavity anyway - so the knobs are not sitting high on top.F.F.
