Marshall amps summary for reference
Started by Twinfan, December 02, 2007, 05:30:24 PM
JamesHealey
im tossing up at the moment if I should get an older marshall next year or so.. I really like marshalls especially the 800s and SLPs
kluson
just one thing the JTM 45 is a 30 watt amp and not 45W. Actually testing mine I can get 27watts. I have played around with output transformers and found all kinds of results  based on the different clones around today
It really is a sweet and very versatile amp.
till the next time..........
They vary, depending on components and valves used.  Around 35w is a fairly 'normal' output.  My JTM45/100 (when it's built) will probably be around 65 watts not 100.
kluson
hi twin fan,
how are you measuring that output?
cheers
kluson
I'm not measuring anything!  Just going by what I've read in several places and what I've been told by people.
kluson
Hi Twin fan,
when you measure them you'll be very lucky indeed to get 35w, as I said I can get 27 from mine and 19 from my BFDR,  Still loud though!
enjoy your JTM 45 they really are the business amps. Let us know how you get on with the build
Good luck
The fairly conservative output on the JTM45 is because of the OTs used.  The primary Z used (8k) isn't really optimum for the best power transfer.
Marshall solved this later on when they changed to EL34s by choosing the right OT.  The EL34 50w OTs had a primary Z of 3.5k which gives 'at least' 50w on the earlier heads with high B+ (a bit less on the early 70s 50w heads with lower B+)
:twisted:
kluson
Quote from: HEAVIER THAN HELLThe fairly conservative output on the JTM45 is because of the OTs used.  The primary Z used (8k) isn't really optimum for the best power transfer.
:twisted:
spot on,! but it does make for a great sound, and it's still loud enough to use with a Live drummer no problem.
JJretroTONEGOD
thanks for that, really interesting info there!
Quote from: kluson
:twisted:
Heh, we'll see how loud it is when I've got my JTM45/100 up and running.
I have no need for another amp but Twinfan got me GASing for a 45/100.  I'd originally planned a dual OT version but it looks like I've secured a really good deal on some b-stock trannies (bent bell-end feet, missing screws and the 4ohm tap cut short).  I can live with those 'issues' in order to get the trannies cheap.
:twisted:
Nice move matey!  Mine should be completed in Feb sometime  :D
You'll probably have yours done first?  You'll have to let me know how it sounds in person.....
JamesHealey
informative.. nice to see this kinda stuff.
already knew it but still useful.
JamesHealey
what about the early 80s JCM800s with no master volume and pre-amp control.. and 4 inputs?
aka the JCM800 MkII's
