Poll
Which do you think is the best?
Boss MT-2 Metal Zone
3 (33.3%)
Boss MD-2
0 (0%)
Danelectro 'BLACK LICORICE' BEYOND METAL
0 (0%)
Danelectro 'BLACK COFFEE' METAL DISTORTION
0 (0%)
Digitech XMM Metal Master
1 (11.1%)
Digitech Death Metal
1 (11.1%)
Landmine LD1 DISTORTION PEDAL
4 (44.4%)
Total Members Voted: 8
Voting closed: December 14, 2007, 12:26:53 PM
Author Topic: What Distortion pedals?  (Read 7387 times)
opprobrium_9
« Reply #15 on: December 14, 2007, 09:31:35 PM »
Quote from: Mr Ed
Although I'd sooner have a Krank Distortus Maximus...
That pedal looks HAWT, i might have to pick me up one of thems!!  :twisted:
  • Truly bad since 1972
« Reply #16 on: December 14, 2007, 10:37:04 PM »
I love my bulldog but got gas....pill might cure it if not am thinkin of getting that guy mentioned here http://bareknucklepickups.co.uk/forum/viewtopic.php?t=10594
to make me something
the_bleeding
« Reply #17 on: December 14, 2007, 11:24:39 PM »
I hope you realize that distortion pedals dont work with the Spiders. Digital preamp doesn't work with solid state distortion circuitry. Thats like expecting to get HUGE differences in tone when switching emg's between guitars, it just doesnt happen.
Get a new amp, one with decent amp distortion.
Nige666
« Reply #18 on: December 15, 2007, 12:02:59 AM »
Ah cr@p, hey thanks for the info....
blue
« Reply #19 on: December 17, 2007, 01:22:04 AM »
Quote from: the_bleeding
what do you mean don't work?  if you mean won't sound great, fair enough, but of course they work.  i've used an overdrive pedal through a pod before with no problems.  maybe you mean booster pedals?  if so, then you're absolutely right, but a distortion pedal will work fine.
Roho
« Reply #20 on: December 17, 2007, 01:21:59 PM »
When I played the Spider II amp, no matter what guitar I played, the amp sounded the same. From el cheapo to high end guitars, it didn't matter, the Spider II has its own sound. It's not like plugging into a tube amp where the characteristics of the guitar come through, and changing guitars changes tones. That's what I love the most about tube amps.
The Spider II also lacks dynamics.
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
« Reply #21 on: December 19, 2007, 02:20:22 AM »
MXR Distortion +?
artypaul
« Reply #22 on: December 19, 2007, 10:45:45 PM »
The Damage Control Solid Metal is a great valve based distortion pedal, and IMHO manages the clear yet heavy sound you're after. Definitely worth an audition.
Paul.
Henk
« Reply #23 on: December 20, 2007, 09:58:57 AM »
Quote from: Roho
You probably also realise what you should do, just take that next step, maybe you should hang on to the spider till you have a sound your happy with.
IMVH opinion the Metal master is the most simple straight foreward, cant really do any harm, metal tone. I still have the death metal pedal, it has the most extreme bottom end boost there is in a pedal, i never turn it up though since its a really cr@ppy pedal, didnt toss it because nobody seems to want one! The death metal pedal only sounds 'good' when boosted with another pedal, on its own it sounds like p@@p.
Very high gain pedal is the MI audio Crunchbox, screamingly loud even if you have the first version, distortion is good but not very natural sounding.
If you like oldskool natural sounding drive i would suggest a Proco Rat or Boss OD-1 or OD-3. The OD-1(discontinued) is the most versatile of them all and is very low noise, just the best IMO.
Getting a good metal (like) tone out of decent gear is never much of a problem, try to get some analogue gear together, digital effects or amps always do lack dynamics, they do that for a reason, sloppy playing even sounds good under heaps of digital processing. Still if you actually want to hear what you are playing youll need to make that step eventually.
Best of luck and succes, great things will happen when your gear makes you work for it HARD  :wink:
Nige666
« Reply #24 on: December 29, 2007, 11:10:19 PM »
What about a Line 6 Uber Metal pedal? Chap at my local guitar shop recommended it over a Dime distortion pedal, said it has the same settings like the mid scoop, and was £80 cheaper!
Stevepage
« Reply #25 on: December 30, 2007, 02:31:39 PM »
I'd go with the Metal Master. It's a great pedal for the modern metal stuff and it doesn't have that 'scratchy' tone that alot of distortion pedals have.
silentrage
« Reply #26 on: January 01, 2008, 09:16:57 AM »
strangely out of all the petals I've tried, t he MT2 was actually the best.
I know it may sound strange, but I absolutely hated the sound when I first heard my friend play through it, but after a while of borrowing his it really grew on me, and I eventually bought my own.
hope that helps somewhat...
