Got my new BKP's installed....Check em out!!
Started by brewboy73, December 26, 2007, 11:06:50 PM
brewboy73
I had my guitar tech wire mine, due to me not having any experience with it. A diagram comes with the pups, but I think that it was to coil tap. There is a ton wire maps on the net that you can look at or I'm sure that Tim can tell exactly what to do. My install was a little tricky, because my tech had to remove the entire base plate that the original Gibson pots sat in so that the push pots would fit through the Les Paul top. Sometimes you need long stem pots for Pauls.
shaman
thanks,brew-thats what I want to hear-I have an older custom and standard, so it seems a chambered one would only accentuate the arsenal-WOMD!
brewboy73
No doubt!! My 76 Tobacco custom had the pancaked body. There was the thin strip of walnut inbetween the maple top and the mahogany back. Had so much bottom end that I had to tweak my knobs whenever I switched from my standard to my custom. :lol:
