Quote from: TwinfanHa ha - top clip Hunter!! Like the way you had to get a bit of Led Zep in there ;) The Beat It part was inspired too!
Would you rate the pedal then? Worth buying? Not tone sucking in any way?
errm, sounded so emo, I had to get the stairway out
Not tone sucking, looks cheapo plastic but has weight and quality.
Though I only tried it in the loop of the Budda. It is not true bypass, so I'll have to try in front of the amp to give a proper statement, will do tomorrow.
Are you planning to use it in the FX loop or in front?
