Author Topic: MIJ Fender Stratocaster question.  (Read 11441 times)
Scotty477
« Reply #30 on: January 19, 2008, 11:14:28 AM »
Quote from: Henk
About tonewoods:
http://www.bothner.co.za/articles/bodywoods.shtml
Your E series strat is most likely Basswood, you can check the neckpocket to see. There are different grades of Basswood, in general the darker Tan core produces better tonewood then the pale yellowish sapwood. Alder has a red or purple color to it so its easy to distinguish. Clear finished strats of that time were sometimes different wood, but mostly also just BW.
Most of the JV's were made with the correct vintage bodywoods, so either Ash(50s) or Alder(60s), but there were also some build with Basswood bodies or Sen(looks like Ash).
Excellent site Henk, thanks.
On a side note. My strat has a few small nicks in the lacquer at the neck joint and the side. The colour would appear to be reddish, much more like the pic of alder than the basswood one from that site.
I'm tempted to try and take the neck off just to find out now  :D
Fourth Feline
« Reply #31 on: January 19, 2008, 11:36:54 AM »
Yes, thanks for showing us that link Henk, very interesting indeed.  :D
Henk
« Reply #32 on: January 19, 2008, 12:40:38 PM »
Quote from: Machinehead
The nicks are not a good indication of the actual wood color, you need to check on a bare/untreated patch which usually is much lighter.
If you do take off the neck make a mental not of how tight the screws are and if you put it back line it up well, pushing it gently towards the body for maximum contact. I left both E strings on the body to get the neck exactly right.
The smarter thing to do is to call the tech who set it up for you, he might remember what bodywood it was, at least worth a try IMO.
If you are going to take it off, make a pic if you can, with the neck as a reference if possible, like this pic of my JV.
Note that the wood patch is a bit pale due to the flash, so the pinkish tone is a bit more red in reality.
The color of the wood where the paint chipped off is much darker and some of the pigmentation of the 3 tone sunburst is in there.
I just love that vintage-y JV feel!!!!!!!!!!!!!
Scotty477
« Reply #33 on: January 19, 2008, 01:08:26 PM »
Thanks again Henk.
Hmmm ... Call the tech that took the neck off a few days ago? Of course I thought of that .. erm ... there's no way I wouldn't have .. um .. thought of that   :oops:
/em runawayandcallthetech
