Started by WezV, February 06, 2008, 08:15:37 PM
Quote from: WezVb]should i or is it a bad 80's idea.[/b]
QuoteYou have another whiter than white guitar in at the moment? Does it happen to be a swanky superstrat?
Quoteactually, if you want 80's, it's got a 24 fret neck and a Kahler, it's gotta be neon yellow!!
Quote from: WezVi was originally going to go for a clear or trans finish but after a little experimentation gone wrong there are a couple of small areas on the body that wont look as good as i want... so it will be a solid finish!!QuoteYou have another whiter than white guitar in at the moment? Does it happen to be a swanky superstrat? i reckon it might beQuoteactually, if you want 80's, it's got a 24 fret neck and a Kahler, it's gotta be neon yellow!!I did seriously consider that but i think white is garish enough for me at the momenti reckon i will go with the white, do it over the neck as well and maybe experiment with a few different scratchplate shapes and colours once its all together
Quote from: WezVthe good thing is i can make a scratchplate and see what it looks like before finally deciding to attach it. this is one of my old guitars and i really liked the white with black scratchplate
Quote from: WezVno, i still have that one... kinda wanted to hold onto it for a while!Its called 'THE VETERAN'
Quote from: WezVhttp://uk.youtube.com/watch?v=M7GelTd6MwE
