New toy for the evening... ;0)
Started by Twinfan, February 18, 2008, 10:27:26 PM
I like that neck joint design  :) - presumably it's similar to what ESP call a "set-through".  I imagine it must be super-sturdy too?
Quote from: Philly QI like that neck joint design  :) - presumably it's similar to what ESP call a "set-through".  I imagine it must be super-sturdy too?
If it is - That's what I have on my Viper.
Never saw the deepth of the joint on these ESPs, but could be it or longer, untill the bridge, etc...
It's getting nice Wez!!
Which wood for the neck/fingerboard?
neck is mahogany and wenge, fretboard is granadillo which is another rosewood substitute
This style of neck join has intrigued me for a while so i thought i would give it a go.  some people make them longer to go under the bridge, and some dont.  In this instance i didnt because i can still get another neck from the same blank.  I think phil kings new bass has a similar idea but the neck extends all the way to the bridge and peeks through the top... that would have been a lot harder to do than this
Quote from: Philly QI imagine it must be super-sturdy too?
definately - the explorer i did has a similar join without the top and it does give a very solid feeling neck join... i dont like guitars you have to be gentle with!!
So far i have only done joints like these with single pickup guitars... not too sure you will see the benefit as much with a neck pickup route thrown in, but it should still be a lot stronger than the traditional ones.  Not saying i wouldnt do it with a dual pickup design - just that its an especially good choice for single pickup guitars
nice..is making me want a gretsch again
better, thanks :wink:
I hope people realise i am kidding - i wouldnt mind a gretsch myself... making guitars is not as much a cure for GAS as you would expect
it isn't...glad I didn't take up that as well then..have liked all the guitars you've done.....still like the Solid Paduak Vendetta
well maybe i manage to resist the GAS a bit more- but it does get broekn down into WoodAS, PickupAS, HardwareAS ToolAs and lots of other aquisition syndromes
yeah can understand that..mine started as guitars..then went a bit gear mad....now i've built a pedal and a amp..want more of them to build...
might have to sell my Orange Tiny terror as it isn't getting a look in
