How many pedals is too many pedals?
Started by Catalyst77, February 21, 2008, 11:38:00 AM
kellar
18 pedals?!?!  :o
I have 2, an SD-1 and a Wah.
I'm surprised you still have a signal by the time it reaches you amp!
Catalyst77
Quote from: kellar18 pedals?!?!  :o
they are in a looper programer; So if I were just using the channel on my amp they would all be bypassed.
I have 3:
Fulltone OCD
Boss DD3
Zvex Seek Wah II
I will probably get some sort of phaser and that'll be it for me.
Quote from: Ian PriceI will probably get some sort of phaser and that'll be it for me.
That's what they all say :wink:
the_bleeding
i own... 6. (maxon od808, boss dd6, boss hm-2, dod fx90, crybaby, tuner)
But i only use 2. the maxon and tuner.
i do want a new wah though so i can use that.
badgermark
I have a custom built triangle Muff and delay in one box, and a crunch zone alongside a boss tuner. All i need really.
headtheball
A three pedal man myself. A custom boost/thickener pedal built into (the shame!!) a Behringer chassis (It's kinda like a treble booster, but instead of treble, it has it's "spike" in the low-mid region), a slightly altered Crybaby, and a delay.
The "thickener" is on 50% of the time for band purposes, the wah gets a fair bit of use, but the delay is really not being used to anything like it's full potential, more as a doubling effect, so I might either quit using it, or change to something analogue for a smoother sound, as total delay time is of very little concern to me.
The only other thing I want/need is a tremolo pedal, but I can't seem to find one that'll do what I want. Really, I want something like one of those new Fender Volume/Tone pedals, with the up-down motion controlling speed, and the left/right controlling intensity... If only they'd build it.
Evil, Evil, Evil...
Omar A Rodriguez-Lopez from The Mars Volta has over 100 and reckons he needs all of them!  :lol:
hamfist
C'mon, get with the program. Do a google search for "true bypass looper", and you'll find out about the proper way to set up a pedalboard.
kellar
I am perfectly aware of what a true bypass looper is. I meant that as a joke, referring to his 18 pedals. Humour, remember humour?
Antag
I have 2
Me too:  MXR Chorus & Morley "Bad Horsie" wah.
Having said that, I do plug into a 4-channel amp & have a MIDI FX processor in the FX loop for reverb & delays, so I'm hardly stuck with a limited tonal palette :)
I've got 4 that I use. A Screaming Demon Wah. A HBE Dos Mos. A HBE Power Screamer with fat boost. And one of those Yamaha Magic Stomps. It's ok for a couple of things. My Dos Mos is my Favorite. I was playing it through a 12 watt Marshall last week with my Charvel 6 with the MM and TS Pups and I thought it sounded better than my mates DSL. Thing is so did he!
I have:
Vox 847
Digitech Wammy (the old red one)
Digitech Main Squeeze
Boss HM-3 (a gift, pretty much unused)
Boss EQ 20
ISP Decimator
The only ones I use with any regularity are the EQ and the Decimator. Niether of which I could get by without.
Thinking about getting a delay and a chorus, but I cant really be arsed.
Quote from: MDVI have:
Vox 847
Boss EQ 20
ISP Decimator
Do you still need the decimator with the new amp Mark? Does it give you that Dimebag kind of feel?
