Keeley MT-2 Twilight Zone Mod
Started by Ratrod, August 26, 2005, 12:38:23 PM
HJM
I didi a gig last year, first lighting wash was bright open white.....I couldn't see any of my LED.......at which point I umplugged the pedalboard and went straight into the amp!
rinse_master
Quote from: HJMDoesn't veryone buy a Metalzone once when they're 18???
I didn't, but then again I had a mate who ran one through the clean channel of his Mesa Dual Rec. and I never really liked it too much.
He did use his OD channel too, used the Metalzone for higher gain stuff and the OD for mid/high.
The funniest thing was that he played a stock 3xsc Strat and he was in a Hardcore band, well I though it was a bit odd...
"What frequency are you getting? Is it noise or sweet, sweet music?"
That's one of the funny things about the Metal Zone; it can make a banjo sound metal.
rsterren
hell no!!
heavy metal 2... there was no metalzone yet...
"There's always something new to learn."
-- Slash  .
I tried a Heavy Metal 2 once. Hairball distortion. Ultra sick. Not my taste though.
HJM
Quote from: RatrodThat's one of the funny things about the Metal Zone; it can make a banjo sound metal.
That is sooooo true! At least the Keeley is more transparant
I'll probably will be sending Keeley the pedal in a couple of weeks. I'll write on the order form HJM and Tim said hi.
I've been droolin' over the Keeley Tube Screamer as well. Might get that one too when my budget allows it. The clips are great. Perfect for rockabilly too. It sounds like a Fender amp set real loud. Could also be nice too boost the Tube Factor.
Shag101
Hi Ratrod,
Did you ever get your mt-2 modded?  If so, I was wondering if its worth it.  thanks
Warpig = '88 Charvel Model 1
I haven't yet. It's not a priority at the moment. But I will, someday.
tewboss
I know its been mentioned earlier in the thread, but I've got the analogman version. Mike does use the parts he uses in the Tubescreamer mod (I think he uses two of the tubescreamer chips). I can't really give a good description as I'm not really a good player so couldn't really do it justice.
