EQ pedal
Started by kellar, March 03, 2008, 03:59:10 PM
kellar
I'm looking to buy a cheap EQ pedal for home use that is decent. Any recommendations? I was looking at the Behringer, which is dirt cheap so I am a little hesitant. Other ideas??
will you uses this in the FX loop, or in front of the amp?
behringer is very noisy in front of the amp.
never tried the dan electro EQ, but it gets good comments on here and is cheap.
best EQ pedal i ever used (and still use regularly) is the Boss GE-7 with Monte Allums 'plus' mod. if you need a serious EQ pedal, i highly recommend saving and getting that.
if you dont like modding, the MXR one is probably about the best commercial EQ.
Save up and get a GE-7.
Or really save up and get a Pultec. PDT_008
i have a behringer. horrible pretty much. Pretty noisy in front, and the bypass is just abysmal.
kellar
I will just be using it in front of my EVJ at home. I am trying to brighten it up a bit as that amp can be quite dark. I figure the best way to do that is EQ.
Unfortunately, since I am only noodling around at home right now, I don't want to drop much money on one.
probably get the danelectro then:
http://www.dolphinmusic.co.uk/page/shop/flypage/product_id/21968
twinfan recommend it some time ago. if you want cheap one can hardly argue at that price.
kellar
I'll check it out.
Thanks a lot!!
TomW
I have the MXR 10 band EQ pedal and its great, much better than the behringer
Riff Raff/Stormy Monday, Holydiver and Mississippi Queen!!!
www.myspace.com/therealamorist
opprobrium_9
its not terribly cheap, but not terribly expensive, and if you want to do some extremely detailed eqing this is the thing for a rack set up http://www.bbesound.com/products/equalizers/EQA231/index.asp
kellar
Wow, that's a bit more than what I am looking for right now! :lol:
Looks awesome though.
Mr Ed
MXR 6-Band EQ.
You need nothing else.
lifted
I've got the DOD FX40B  8 -band eq  for $35 ,  and am quite pleased with the quality and quietness for the money  It  did wonders for my tone   Good luck in chosing!
Irish Tour/ Mule Set,    Apache Set... in Strats .... Nailbomb Bridge,Cold Sweat Neck in Ibanez S540
goddamn electric
I use an mxr 6 band, sounds good in the FX loop, although there can be quite a bit of hiss. also sounds great straight into the amp in front of a distortion pedal.
If you want to brighten up an EVJ you'll ultimately need to mod it.  The Danelectro Fish N Chips is a decent enough EQ to try first though.
A set of JJ valves also helps the amp's tone quite a bit.  A cheap tweak too as there are only 2 of them  :)
Boss EQ20
Not so much 'cheap' as 'awesome'.
