Author Topic: What's this Buzz Feiten system?  (Read 10318 times)
Pale Rider
« Reply #15 on: March 08, 2008, 07:35:48 PM »
Quote from: PhilKing
I built Ben's guitar and the way I did it was to get a standard neck cut for a Fender style nut.  I then routed off part of the reverse curve where the fingerboard joins the headstock.  This gives about .5 cm between the nut and the locking nut.  Ben has screw in lock nuts not bolt on, however that shouldn't make a difference.  On the neck we were using (a Warmoth), the truss rod adjuster is on the bottom of the neck and also on the lower side at the heel.
Thanks PhilKing! Actually I'm interested in a neck through custom guitar so I guess the truss rod adjustment would be on headstock?
I hope it's easy for a luthier to build the neck a few mms longer after the nut so I don't have to put anything on headstock. It won't affect the scale once it's after the nut I guess.
Painkiller :: Miracle Man :: Holydiver :: Trilogies
::::::::::::::: ME(N)TAL DISTORTION ::::::::::::::
« Reply #16 on: March 08, 2008, 09:55:03 PM »
Quote from: HeavyAxes
The truss rod adjuster could be put at the body end of the fingerboard, but it would need to be a wheel type.
Pale Rider
« Reply #17 on: March 08, 2008, 11:49:56 PM »
Thanks for the info!
I'm certainly going to discuss this matter with the builder (whoever is going to be) before anything. :)
