Main Menu
Tiny Trouble
Started by maverickf1jockey, March 10, 2008, 05:28:14 PM
maverickf1jockey
I have finally got round to replacing the valve that was going wrong in my TT after a sudden change in the tone prompted me to get off my arse and do something about it.
The trouble is that the change has not reverted to how it was; the sound is muddy and I'm not getting nearly enough gain.
I had replaced the dodgy valve with a JJ electronics valve, which as far as I can tell was the same sound as before the change of the valve.
Swapping the JJ round with the remaining Orange-branded valve has helped a bit but it still sounds like utter shite.
I have checked my guitar and my pedals; no problems.
Can you please help; I'm at wit's end.
The replacement valve was a dual triode model if that helps you.
Chris_G
Did you set the bias when you fitted the new valve?
Also, I have on my Matamp LX a switch that switches the amp from pentode to triode - this makes the sound thinner and more fizzy so it may just be the valve you chose.
maverickf1jockey
How would one go about the process of biasing the valves? There is no evident way of doing so unless it is below the valve socket itself.
DeanS
You may wanna take this to the Orange forum- not that this place is without its amp gurus. Just a thought...
Mothers Milk set, VHII
maverickf1jockey
I'm not a member of the orange forum; hell, it's hard enough to put in a showing here half the time. I am aware of the amp gurus resident here (along with a large group who own the TT) and that is why I asked here; I trust the opinion of people here as opposed to people I don't 'know'.
badgermark
I'm actually interested to hear about this too. Biasing amps is something I know zero about, and having a TT myself I think I should learn...
maverickf1jockey
It would appear solely from that comment we have much in common. Have an imaginary present from me to you :gif:.
Sorry about that Badgermark but I'm so anxious about sorting this I've been checking this thread for every 2-3 minutes and I'm going a bit strange...
Interested in finding this out too for my TT
badgermark
Found this; http://www.orangeamps.com/forumtest/topic.asp?TOPIC_ID=14380 apparently doesn't need biased? Still makes no sense to me though.
maverickf1jockey
I also found an ebay guide on what valves sounded like what but it wasn't really in enough detail.
I would think it would be a good idea to do a total refit but the cost is not pretty.
If I could avoid JJ valves that would be good (although the shop I used, RS components, only do JJs.)
After a high gain sound with a fair bit of treble (but not Fender levels). Anybody got any recommendations?
Why not JJ's where they the trouble?
maverickf1jockey
Because the JJ in V1 sounded the same as the busted original but was working perfectly well.
Also they only do one type of 12AX7 (the ECC83 S), which is not a high gain valve and is more useful in a HIFI application.
Lazy_McDoesnothing
Preamp tubes shouldn't need biasing, just the power tubes.  How many tubes does the TT use?  How long have you had it?  If you've had it I while I'd suggest replacing all the tubes.  I just did this with my Peavey Classic 30 and it fixed my problems I was having.  If that doesn't solve it then you have a spare set of tubes and I would take it to a tech.
Chris_G
I've had pretty good experiences with JJ's but they may not be what you're after. Perhaps you could try Electro Harmonix or something? I had a quad of those in a Laney GH50 and they improved the quality of the gain and reduced noise somewhat. If you look at the test reports at watfordvalves.com they may give you an insight into which valves are for you.
Quote from: maverickf1jockeyBecause the JJ in V1 sounded the same as the busted original but was working perfectly well.
JJ make the ECC803S which is their high gain 12AX7
