Effects!
Started by AngusYoung01, March 12, 2008, 05:04:09 PM
AngusYoung01
Quote from: Lazy_McDoesnothing
Quote from: AngusYoung01Any word on the power for Boss pedals though? Does it HAVE to be the PSA adapter?
Quote from: hamfistYes, any Regulated 9V adapter with the same polarity, which supplies at least the current (mA) that the pedal requires will be fine. Remember it MUST be a "regulated" supply.
Alan
It doesn't have to be.  I use an adapter from my digitech whammy to power my boss pedals with no problems.  Just make sure the polarity is the same and that the adapter as at least the same regulated current as the pedal as hamfist stated.
Ooops. didn't see that. Thanks Alan, and Lazy lol.
mA?
Lazy_McDoesnothing
mA = milliamps
It should say on the adapter and the pedal.  Some pedals don't have them though and if they don't you'd have to look it up.
Here's a Boss adapter for reference.
http://www.instrumentpro.com/image.php?src=/Merchant2/graphics/00000001/bosaca120g.jpg
The part where it lists the output is what you need to look for.  Most pedals are 9V and after that it'll list the current value usually in mA.  Also the diagram near the bottom with the little + and - symbols shows the polarity.  It has to be the same as the pedal it's going into.
Another way of showing the polarity:
AngusYoung01
Ohhh, thats cool. Cheers, never realised what that meant!
Heres all the info on my adapter -
PRI: 230v~50Hz  10.8W
SEC: 9V--- 500mA  4.5VA
Is this ok?
Lazy_McDoesnothing
It depends.  What are the specs of the pedal you're going to use it for?  If the pedal is rated for less than 500mA and 9V you're good to go.  Also make sure the polarity diagram matches up on both.
kellar
One more thing man!!
If you order from Visual Sound they have the One Spot that can power all your pedals. They have special adapters that come with it, you can power nearly anything. You can check it out as well on the website.
Visual Sound pedals are all build very well and the new V2 series has a noise gate on nearly every pedal.
AngusYoung01
Sweet! cheers man. I'll look into that because I'll need something to power it all! And I'll make sure to get a V2 H20 then.
Thanks again :D
