Quote from: opprobrium_9Do you have any on a VEEEEEE? Cuz that is where i would put em, i would think they would be particularly uncomfortable since the top straplock bit would be on the back of the guitar, that is what i am concerned about. That and them fitting inside the case, i think it would make an uncomforable fit inside the case with a straplock on a Vee...
Yep, on three Vs and lots of SGs. I don't find the straplock gets in the way at all - the strap sits about 1/2" away from the guitar so your hand can get
under the strap rather than having to reach round the whole straplock mechanism. I suppose it may depend on your playing style and maybe even the size of your hands!
As for putting it in the case, the Schaller (or Dunlop, if you have those) strap
buttons are no bigger than ordinary strap buttons - there'd only be a problem if you left the strap attached to the guitar. The DiMarzio system would take up a lot more case room, in fact.
Quote from: 7thSonReally I just want something that's simple to install, I read that to install schallers I would need to do something with toothpicks because the screw wasn't the right size for the epiphone, but the cliploks would just install fine.
I've
never had to put toothpicks or matchsticks in the screw holes to fit Schallers. In fact with most of my Fenders, Gibsons and Japanese guitars the Schaller screws are bigger than the ones used for the stock strap buttons. I don't know if some Korean guitars may have oversized screws. :?
