Author Topic: Mahogany vs Basswood?  (Read 5743 times)
« Reply #15 on: April 11, 2008, 05:32:35 PM »
try a wylde overdrive
it pushes the amp a lot harder and doesn't cut your bass
Nolly
  • Global Moderator
« Reply #16 on: April 11, 2008, 05:47:19 PM »
Quote from: Eric Hellstyle
I actually use the tubescreamer to deliberately cut the extreme low bass - it gives you a far tighter sound ;) Also, the TSs mid-spike makes your guitar tone cut through a mix more easily.
Zaphod_Beeblebrox65
« Reply #17 on: April 11, 2008, 09:11:06 PM »
Quote from: Nolly
Quote from: Zaphod_Beeblebrox65
Would you say the Painkillers are a better choice than the Nailbombs then?  At least for those kind of Sikth ish tones and fluid sounding leads in the neck?
I wouldn't say better necessarily, but they can certainly do both of those things extremely well plus a whole load more. At the end of the day, you really should give Tim a call - he'll know the right pickup for the job. Plus it's really nice to be able talk to the guy who will make your pickups.
Also, don't forget that I used a tubescreamer (set with the drive at 0) in front of the Laney in those videos ;) I'd seriously recommend it if you're not doing that already
Way ahead of you  :lol: I've had a Maxon OD808 since before I bought the Laney from you.
I'll see if I can talk to Tim about the pickups at some point; thank.
I have no signature...
