Help! I need a new pedalboard
Started by prozacbear, April 22, 2008, 09:13:56 PM
prozacbear
Quote from: ailean
Did any of you notice how quickly my Blackstar went from the Peavey amp to Sue's pedalboard?  :roll:
I've only borrowed it, you can have it back whenever you want  :D
DIE BENT-FACE!
IT's NB MQ PD's Blackguards C Pigs Trilogy suite Black Dogs Cold Sweats Painkillers
opprobrium_9
prozacbear, what kind of amp do you have?
hamfist
Quote from: opprobrium_9prozacbear, what kind of amp do you have?
The lady hath a Rockerverb 50.
prozacbear
Quote from: hamfist
Yep what he just said.
Also this may be a daft question but I looked at this
http://www.spider-engineering.co.uk/music/typeproducts2.asp?id=3125-2672
The power supply costs about £70 on its own, or £50 with the board . Is there any advantage to having something like this rather than just plugging multiple normal 3 pin plug 9v adaptors into a normal power bar/ plug adaptor thing (the sort of thing you get from Woolworths for £1.99)? Apart from the obvious less wires thing. :?
DIE BENT-FACE!
Less wires, often more stable current, much much more practical to have one plug - really.
hamfist
Quote from: prozacbear
It will probably be be no better than using a couple of reasonable 9V adaptors, from Maplins etc. with a couple of daisy chain leads to spread the power around. Personally I would go to Maplins rather than Woolies, as the quality of the PSU's will be better. They are about a tenner each if I remember rightly. I run my whole pedalboard from two such Maplin adaptors, and it's REALLY quiet. I would see no need to change except for neatness. I have run up to 6 or 7 pedals off one PSU, no problem (as long as the PSU can provide the milliamps required for all the pedals).
 A very important point about Multi power supplies like the Gator G-Bus 8 is whether each output is actually isolated from each other. If they are electronically isolated, then it is theoretically the best scenario, and is effectively the same as giving each pedal it's own dedicated PSU. The Gator G-bus 8 does not claim to have isolated outputs, therefore one has to assume that it probably doesn't have them.  Multi isolated output PSU's are generally fairly pricy.
 Another point to mention is that some pedals (Line6 pedals in particular) seem to be much quieter with their own dedicated power supply (or their own isolated output from a multi supply) compared to sharing a daisy-chained supply with other pedals.
martinw
I've found standard transformer type power supplies can cause hum when diasy chained up to supply a group of pedals (doesn't always happen though.)
If you get one of these http://www.rapidonline.com/Electrical-Power/Power-Supplies/Desktop-PSUs/12W-25W-DC-Miniature-desktop-switch-mode-PSU/71064 part number 85-2942 you'll find they are the same as the one sold by some pedal board companies, and all you have to do is reverse the polarity, an easy job for someone who can solder.
Custom Built Amps:
www.mjwamps.com
