Quote from: PhilKingYou need a set of Blackguards for the Tele!
I have to add another option into the mix, only because I am loving it in my Zemaitis clone. The guitar is a pearl top over a mahogany body, somewere between an SG and Les Paul in thickness. I have an AV Mule in the bridge and a Stormy Monday neck. The combination sounds great. The AV Mule seems to add another level of tone to the amp, it is like you turned it up to start the power tubes cooking a bit more. I also have a Riff Raff/SM set in one of my Les Pauls and really like that too, but I think the AV Mule seems a bit fatter than the Riff Raff, but will all the clarity too.
Now I am fully lost in land of confusion ...
I'll do some experiments with my RebelYell set. It's F spaced and I have to take the bridge out of my PRS SE, but guess it's worth the effort to just have a reference point - maybe it's spot on, maybe not. Either way I want a covered set with proper spacing, so it's gonna be temporary.
Regarding the Baja Tele, not sure if I want new pickups, I am quite happy with the original ones, plus the wiring is a bit complex with the S1 switch and the 4-way, well probably I am just lazy. The current bridge on the Baja is very hot, almost like a Humbucker, would that be the case with Blackguards, too?
