Author Topic: all the 8s - my 8th V from 1988  (Read 13843 times)
« Reply #30 on: May 27, 2008, 02:13:30 PM »
Quote from: Philly Q
Quote from: gwEm
and a hole for a toggle switch
For coil splitting, or are you adding a neck pickup?
won't be adding that neck pickup ;)
i worked out this little trick... not even a trick really:
on single pickup guitars the only thing I miss is the ability to set two voices which you can select between quickly with a switch - clean with the volume rolled down, and dirty with the volume maxed out. so i add a switch which toggles between the output of the pickup, and the center output of the pot.
« Reply #31 on: May 27, 2008, 03:09:31 PM »
Ah, so pretty similar to Tom Anderson's "blower" switch?  Neat idea.  :)
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #32 on: May 27, 2008, 05:56:22 PM »
Sounds like the switch on my single pickup fernandes, it bypasses the tone and volume circuit. So I can use it to switch between full volume to a preset lower volume, or sometimes I use it with the tone rolled down for a pseudo neck pickup tone that simulates having two pickups.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Re: all the 8s - my 8th V from 1988
« Reply #33 on: October 11, 2008, 07:38:15 PM »
You'll have to bring her roun to mine - for - you know - evaluation purposes :D
OMG - played this guitar yesterday and she is awesome
The colour is a shock to the system, but the guitar simply rocks!
« Reply #34 on: October 11, 2008, 07:51:06 PM »
The neck is a little to small for me, but YES! that guitar is very nice in every other aspect
« Reply #35 on: October 11, 2008, 07:52:28 PM »
I was really impressed by the V when I played it.  The neck has an awesome feel to it and the 25.5" scale makes it totall different to a regular V.  I like the yellow!
« Reply #36 on: October 11, 2008, 08:02:26 PM »
Quality is the best I have seen from a Gibson in a long time (ok - it's an older one - 1988)
Loved the neck shape and yes the 25.5" scale and maple neck / ebony board made it sound v crunchy.
broken cord
« Reply #37 on: October 12, 2008, 04:05:49 PM »
Keeping with the V8, here is my 1978 Dean V.
« Last Edit: October 12, 2008, 04:08:22 PM by broken cord »
Warpig/Mississippi Queen
Calibrated Painkillers
Nailbombs
« Reply #38 on: October 12, 2008, 04:52:58 PM »
nice Dean brokencord!
yeah, i still like the v90 alot. the 25.5" scale and maple/ebony neck totally tightens up the sound. shes now fitted with a Holy Diver - 100% the right choice for this guitar. She absolutely nails High&Dry period Def Leppard.
thanks jonothan, will and phil for your compliments :)
maybe she doesn't have the typical V vibe, but i think its a really good interpretation.
