No reason why he couldn't have done that, it's a very easy mod to do.
The only trouble with those external bias points is that you still have to access the inside of the amp to measure Va, unless you assume it stays the same (which it doesn't) when you change the bias voltage.
It kind of works doing that, but it's a bit inaccurate.
That's assuming you knew what Va was in the first place.
Nice amp anyway!
