Cleaning spray on my guitar...
Started by hhcave, May 22, 2008, 10:10:55 PM
yeah, avoid furniture polish!!
and, just to immortalise this in writing for anyone in the future, avoid deodorant (but only on your guitar)!
glad that bit tickled you Roo
T - cut will maybe be your best bet
The Mer polish works in a similar way
Sometimes with T-cut you find that you start to remove years worth of dried sweat as well - turns your cloth brown - dont panic - just keep doing it
You may want to look up about using t-cut on the web for technique etc
Use a clean bit of cotton cloth - like an old t-shirt -make sure it hasn't got any seams or stitching on the bit you are rubbing on the body as threads can sometimes be scratchy
Quote from: FELINEGUITARSlike an old t-shirt -make sure it hasn't got any seams or stitching on the bit you are rubbing on the body as threads can sometimes be scratchy
yeah, old promotional t-shirts that have been well worn can come in very handy!!!
ailean
shite, sorry I should have been more clear. :(
I'd try the lighter fluid first, it won't damage or remove the finish. Use a soft cotton cloth, apply the fluid to the cloth and wipe the surface of the guitar. I used it on my Tokai LP and it brought the finish up beautifully.
The reason I say try the lighter fluid first is that a T-Cut type polish will remove a tiny layer of the finish, and I don't see the point in doing that unless you have to.
This is the stuff we use, it's the fluid not the gas.
Gibson LP std + Nailbomb set
