Main Menu
Avatar pics
Started by hamfist, May 23, 2008, 08:38:10 AM
gingataff
Quote from: hamfist
Quote from: maverickf1jockeymine weighs in at just over 2kb. :twisted:
Now that's just boasting !
And this isn't?? :wink:
Quote from: _tom_Yeah I resized mine in photoshop
I see a rainbow rising
Look there on the horizon
And I'm coming home
ailean
Try adjusting the compression ratio, most photo manipulation software will have some kind of 'quality' setting so you can offset compression against image quality.
Edit: And make sure you are saving as a GIF or JPG! BMP files are uncompressed and huge by comparrison.
Gibson LP std + Nailbomb set
Quote from: gingataff
Quote from: hamfist
:lol:  :lol:
hamfist
Quote from: aileanTry adjusting the compression ratio, most photo manipulation software will have some kind of 'quality' setting so you can offset compression against image quality.
Even the lowest quality option of a 25x25 pixel jpg still saves as a 15kB file on my software !
maverickf1jockey
Use .gif ; it's much smaller than a .jpg and you should be given the opportunity to optimise the palette for the web, reducing the size of the file.
You'll have to go for the best compromise between optimisation and quality you can get.
Scotty477
Hmm
I wonder if mine still works?
