Machineheads, what's your preferance?
Started by Jonny, June 06, 2008, 11:34:08 PM
Quote from: dave_mcoh, i'm fine on guitars with a locking nut, it's the ones without which are the problem.
Why does the locking nut make any difference when it's the same type of tuner?  :?
Do you string up, get it roughly in tune then clamp it quick before the high E falls off its tuner?  :lol:
Quote from: Philly Q
Quote from: JonnyI am completely lost in reading that Philly. I just want to replace the die-cast tuners in my Ibanez without having to do any extra drilling, lol..
:lol:  Show us a picture of the back of the headstock.
I'd guess you'd be fine with Gotohs, Planet Waves or some Schallers, you'd definitely need to drill to fit Sperzels.
Do you want locking ones?
Think locking would be a bit pointless if the locking nut was present? Aren't they more expensive?
I was thinking Planet Waves, since it makes it easier on the re-stringing.
i'm a big fan of the planet waves ones although its sometimes difficult to trim the string with thicker gauges
this year i have mostly been using sperzels - relatively lightweight and quite customisable... i like that the tuner can be taken apart and swapped for left handed and the shaft feels really solid  with no wiggle... the planet waves also have very little wiggle
nobody likes a wiggly shaft!!!
Quote from: JonnyThink locking would be a bit pointless if the locking nut was present? Aren't they more expensive?
Planet Waves are locking!!  :lol:
http://www.planetwaves.com/ptoolsdetails.aspx?ID=5
Looking at your pic, those are the type with no set screw, so they're probably held in place by a pin as I tried to describe.  These Wilkinsons might fit:
http://cgi.ebay.co.uk/6-in-line-Wilkinson-chrom-locking-guitar-tuners-No-3or4_W0QQitemZ140207733046QQihZ004QQcategoryZ22672QQcmdZViewItemQQ_trksidZp1742.m153.l1262
I don't know if they'll be any better than what you have already, though.  For most other tuners, you'd need to drill holes for the set-screws - for example:
http://cgi.ebay.co.uk/6-in-line-Wilkinson-chrome-locking-guitar-tuners-No-2_W0QQitemZ140232876548QQihZ004QQcategoryZ22672QQcmdZViewItemQQ_trksidZp1742.m153.l1262
Quote from: WezVi'm a big fan of the planet waves ones although its sometimes difficult to trim the string with thicker gauges
I prefer Sperzels myself
The planet waves ones are good too but a pain in the arse if you are doing tech work and need to take the strings off again to make adjustments
You have to use a new set of strings each time!
You might go through 6 sets of strings on a tricky job- argh!
But they are pretty stable otherwise
badgermark
Quote from: FELINEGUITARS
I found this also, when replacing pickups in a strat and messing about with switching I had to pull the scratchplate off and on a lot. Found a cool way of getting round it.
Instead of pulling the string through and tightening it while taught, put it through then give it a few cm of slack. Then tighten up the screw and turn till it clips. Gives you a slight bit of extra string on the post, still locked and when taking them off you can pull it a bit tighter and snip the end off when tuning up next. Bloody hard to explain in text...
Oh dear. I kind of contrdicted myself there.
I have three exams on Firday give my brain a rest!
Quote from: JonnyOh dear. I kind of contrdicted myself there.
Bad time to make any decisions you might regret later!  :wink:
Good luck with 'em!
avdekan
Only had experience with schaller locking tuners and sperzel locking tuners.
I liked the schallers better because of the weight!!!
the sperzels just feel kind of cheap compared to the schallers, + the superior turn ratio of the schallers makes precise tuning easier for me.
And I believe the extra weight at the headstock increases the overall sustain of the instrument (might be another guitar voodoo thing but I still believe in it, because guitar tone is all about guitar voodoo  :lol: )
Guns don't kill people, Bare Knuckles kill people!
tremblox
Too much talk of Sperzel and Waves here :)
My faves: LSR gearless tuners. 40:1 ration (or something like that). These are locking micro-machine tuners with a linear pull. (micrometer like action).
Some people find them ugly but I find them pretty cool extremely practical - once an initial learning time has been experienced. They work wonderfully and have enabled me to remove the string trees from my strat (behind the nut bends) and have given me unprecedented tuning stability despite a floating vintage trem.
Well worth checking out.
 cheers
       tremblox
hideous
I use Gotoh 381 on my Floyd guitars. Stiff to turn yes, but that's the feel of quality. Superb machineheads, can't fault them.
I have Sperzels on my Fly Mojo (no locking nut), and they are excellent too.
JJretroTONEGOD
I have Sperzel locking tuners, and my guitar rarely goes out of tune, and when it does it is only ever an extremley tiny change in pitch that most people wouldn't be able to hear. It stay's in tune sometimes perfectly for over a month.
Quote from: JJretroTONEGODI have Sperzel locking tuners, and my guitar rarely goes out of tune, and when it does it is only ever an extremley tiny change in pitch that most people wouldn't be able to hear. It stay's in tune sometimes perfectly for over a month.
+1
My Viper has stayed in tune perfectly since I bought it.
i think so, yeah.  :lol:  :lol:  :lol: problem with having your first (and second!) guitar with a locking nut, you never learn properly, then it's too late to ask and it's embarrassing... :lol:
i think i've got it sorted now, anyway. :)
Bob Johnson
In my humble opinion the Gotoh 510 tuner is probably the highest quality tuner on the market right now. Not everybody likes the rounded smooth very Japanese styling of them but they are incredibly smooth and come in two different gear ratios. Personally I've had some real quality issues with Sperzels and have sent several sets back with bits missing or rough gears.
Regards,
Bob Johnson
Legra Guitars
