Author Topic: Ceramic Warpig, Cold Sweat, Irish Tours, Monster Miracle Man  (Read 24937 times)
Re: Ceramic Warpig, Cold Sweat, Irish Tours, Monster Miracle Man
« Reply #15 on: July 07, 2008, 02:23:18 PM »
Thanks folks  :D
Ibanez2570z
    • Metamorphosis
« Reply #16 on: January 08, 2009, 12:42:43 PM »
Great song and tone as an idea. Obviously your going to work further and harder on it.  :guitar4:
Awesome didn't realise you were registered on here. You can guess who I am as I also use the Warpig and Cold Sweat in an Epiphone guitar haha :P
Spooky
« Reply #17 on: January 08, 2009, 10:26:02 PM »
Threadnomancer!
Yeah, this is getting an overhaul with the rest of them. Just waiting on my 4-way splitter, SD twin tube mayhem and re-amp box to realise my new recording method/s. (Hint - 4 trackings a pain and so's having to find and stick with a tone or replay everything when you find a better one)
Welcome to the boards, Craig :D
Ibanez2570z
    • Metamorphosis
« Reply #18 on: January 09, 2009, 01:09:37 PM »
So the reamp box. I understand this part because the output of a guitar pick-up is entirely different from the output of professional recording equipment. What is the purpose in simple terms like why do you need one apart from what is mentioned above?. You can record without out one so what does it do specifically?
SFX-04 Twin Tube Mayhem LOOKS impressive.
 PDT_002
Spooky
« Reply #19 on: January 09, 2009, 01:32:00 PM »
I spend hours faffing with sounds and never get any playing done.
If I record a direct signal from the guitar to my RME then I can use the reamp box to take a line level signal back out of the RME later and into anything with a high-z input for pickups (amps, preamps, modellers) later. This means you can focus on getting good takes and change the sound to whatever you want later.
With that and my splitter I can line into (in orginal takes or reamped recordings) any combination of 4 of my bits of kits and record the same take with loads of different combinations of gear and settings without having to play it perfectly again and again, which gets very time cosuming and is hard work!
Between this and my PB, 4 mics, tonelab LE, Pod XT, JD10, TTM, Vox VTXL and an amp that HTH and I are going to hammer out, I should be able to realise my ultimate plan - double track through 2 or more things at once so I can use lower gain for clarity, but have the sounds add for thickness and blend two or more tones in a way that plays to the strengths of the seperate tones and masks their weaknesses, rather that do the same with 4-tracking, which is also onerous to get all the takes to be good and very unforgiving, since two tracks panned in a stereo field can tollerate maybe 5 to 10ms of differential in attack, but out of the same speaker even less that 5ms between note strikes fouls the attack of both notes and makes muddy sloppy sound (yes, I've measured this by zooming in in cubase on what sounds synced and clear and what doesnt).
Muzzzz
« Reply #20 on: January 17, 2009, 03:30:14 AM »
Wow! This shite is good! Very Isis-esque post-metal vibe to it all.
Top Stuff!
{Insert witty signature HERE}
« Reply #21 on: January 18, 2009, 06:28:15 PM »
Thanks dude :D
(I lOVE Isis)
« Reply #22 on: January 18, 2009, 08:32:11 PM »
that sounds pretty good. :) giant file, though, took me ages to successfully download it (and that was just the intro!)...
sounds a wee bit like corrosion of conformity, maybe?
« Reply #23 on: January 21, 2009, 12:55:41 AM »
Cheers bud
I can see how you'd see coc in there. Not the vibe I was going for, but yeah. That said one of my tracks has been compared by different people to Isis, battles-but-with-distortion, korn (ewwwwww!), early machine head and a couple of others I forget. I can only discern from that that it doesnt really sound like anyone :lol: (A full rework of that track is on its way! The old version is kicking round on here somewhere, but its changed. A lot. Will post up when ready).
WeavingSpider
« Reply #24 on: March 13, 2010, 01:06:47 PM »
Are you in a band?
It's truly an inspiration-song for me...
Loved the tone__
Which guitar are you playing? (sorry if you already mentioned it...I've lost it!)
Gibson Les Paul Custom Silverburst Limited Edition | Dean Cadillac Classic White | Dean V Black Gold
« Reply #25 on: March 13, 2010, 01:23:12 PM »
Thank you :)
Doesnt look like I have a band any more - the vocalist that was the only other even slightly active member said he doesnt want to do vocals any more (odd you should ask, as he said this just last night), so Invective (as I'm now calling it, rather than Mortal Coil) is a solo instrumental project (something I decided barely an hour ago).
That of course means the tracks are going to have to be re-written to stand alone without tailoring the structure for vocals, but all the better.
If you liked that there are a couple of other rough tracks
http://bareknucklepickups.co.uk/forum/index.php?topic=19791.0
http://bareknucklepickups.co.uk/forum/index.php?topic=13664.0
All of them use my Legra MDV602 http://www.legraguitars.co.uk/mdv602.htm and memento mori uses my still relatively new Legra Aurora http://bareknucklepickups.co.uk/forum/index.php?topic=19131.0 (finished round page 7 or 8 or so)
-Oby-
« Reply #26 on: March 13, 2010, 02:02:10 PM »
Very Nice!
Great Idea
What Guitar you used??
« Reply #27 on: March 13, 2010, 09:41:21 PM »
Thanks! It was my MDV602 (see post above for link), which was then equiped with a c-pig bridge.
