Author Topic: effect of back/porting, material and size on cabinet  (Read 9228 times)
jpfamps
    • http://www.jpfamps.com
Re: effect of back/porting, material and size on cabinet
« Reply #15 on: August 06, 2008, 04:47:23 PM »
We've tried a cab with a removable panel on the back. It seems like a good idea at the time however you need to make sure that the removable panel makes a very tight seal with the rest of the cab. Also if you use self tapping wood screws there is a finite limit as to how many times you can unscrew an screw up the panel. You could go for T-nuts I suppose.....
