Author Topic: Looking for a vintage neck HUM to pair with Nailbomb.  (Read 7241 times)
Fikealox
Re: Looking for a vintage neck HUM to pair with Nailbomb.
« Reply #15 on: August 06, 2008, 08:08:44 AM »
I'm not normally a fan of quilted maple, but that's one of the best quilts I've seen on a Horizon :) The trans-blue is a great look, too
BKPs (soon): CS, TS.
kellar
« Reply #16 on: August 07, 2008, 06:27:08 PM »
If the Nailbomb is a bit dark in the bridge and you want something to match it, why not think about a Black Dog? They are on the hotter end of the vintage side and seem to be darker than the Cold Sweat that was previously mentioned. :)
Peteshreds
    • Personal Myspace Music
« Reply #17 on: August 07, 2008, 08:34:53 PM »
I'll definately consider it. I'm not going to be making my purchase anytime this month, but thanks for the tip.
Noodle. I'm dooling over that trans blue man. Its like looking into the ocean, hahaha.
That guitar is definately on my shopping list, wouldnt mind having 2 NT-IIs in my arsenal.
www.myspace.com/peteshreds
page and music under construction!
« Reply #18 on: August 07, 2008, 10:43:04 PM »
Keep in mind that the Nailbombs are pretty dark-sounding pickups, even in the bridge position (though less dark than in the neck).
:O mine isn't! I find it quite bright. A definite high-mid peak
Fikealox
« Reply #19 on: August 08, 2008, 03:01:48 AM »
Hmmm, that's weird! It might just be a case of my being used to strats and superstrats with things like Dimebuckers and Painkillers in them
HairyChris
« Reply #20 on: August 09, 2008, 10:33:55 PM »
I have a Miracle Man paired with a Mule... No problem with the output mismatch there, and the Mule kills the 59 (and I like the 59 as a pickup). I'm another person with a Cold Sweat set in a PRS, fantastic but not as warm as the Mule.
il˙ti
« Reply #21 on: August 09, 2008, 10:38:49 PM »
Bridge model or neck model? What's the dc resistance?
Wintersun from this forum had a Mule (7,1k neck model which I own now) paired with his Nailbomb in the bridge and he could not get the output to match.
Crawlers, Mule-7s
HairyChris
« Reply #22 on: August 12, 2008, 03:57:28 PM »
Don't know the resistance but was bought as a calibrated set.... If this means that the Mule was wound hot then apologies!!  :P
Nolly
  • Global Moderator
« Reply #23 on: August 12, 2008, 04:41:49 PM »
Are you sure it's a Mule? Calibrated sets usually refer to two of the same type...
HairyChris
« Reply #24 on: August 12, 2008, 06:46:56 PM »
cr@p, you know what I mean... I think.... They were bought as a set...
Nolly
  • Global Moderator
« Reply #25 on: August 15, 2008, 12:17:18 PM »
Ah ok. I'd imagine that if Tim knew they were going as a set, he'd want to up the output of the Mule by one way or another. They'd be very mismatched in output otherwise.
