Author Topic: Caparison Horus  (Read 6744 times)
andrew_y
Re: Caparison Horus
« Reply #15 on: August 21, 2008, 05:12:02 AM »
i have a question maybe i should have asked earlier....all along i've been avoiding bassy BKPs cuz i was afraid of muddiness but having lots of bass doesnt have anyhting to do with clarity right?
I love that arch enemy and nevermore tone....dark, crushing, open sounding. Painkillers are like the oppposite of what i want- a little too tight and focused.
I read some where to get that u go with a a-pig, or nailbomb.
Eric- holy divers sound awesome too.
Last question before i make my decision...difference between a-pig and nailbomb, tonally? Both organic...both loads of low end...
Re: Caparison Horus
« Reply #16 on: August 21, 2008, 08:03:20 AM »
I can only reply with my experiences about the bass side of things. I have a miracle man, which has a LOT of bass, but is super tight, like the painkiller. The ability of your amp to handle the bass output might be what you're mistaking for muddiness from the pickup - in this case, boosting in front of the amp (thereby removing a little bass in the process, depending on your booster) will tighten the amp up a lot, still leaving you with bone-crushing bass!
Your statement that you've been avoiding high-bass pickups because they might be muddy implies that you want a tight pickup, then you go on to say you prefer a slightly looser pickup... which is it? :)
None of the BKP range will get flabby, so I wouldn't use the worry of that as a discriminatory tool in your pickup choice.
Hope this helps,
Roo
