NCD => Bogner 4x12
Started by hunter, August 31, 2008, 05:09:16 PM
Quote from: hunter on September 01, 2008, 12:32:36 PM
Quote from: indysmith on September 01, 2008, 11:21:48 AM
Awesome cab - all it needs is a VALVE AMP on top :P
OK, I'll put my Shiva on top and hide the rack behind the Cab then? Comeooon guys, that's ridiculous :O)
certain rockstars have made bigger deceptions ;)
Woogie
Bogner cabs are very nice, indeed. I rue the day my rehearsal space replaced the Bogner cabs with Diezel/Roccaforte.
excellent! those bogner cabs are meant to be great, they look very classy too... i think i've tried the 2x12? seemed pretty nice, but i was trying amps rather than cabs that day, just happened to be the cab i was plugged into. :)
Quote from: TwilightOdyssey on September 01, 2008, 01:34:16 PM
Wow, either way this is rather impressive, at a rehearsal space I would more expect Behringer 4x12s :O)
Just played again using the PRS with the RebelYells, a Budda model in the Axe and turned the Carvin about 1/4 up (in mono bridged, so around 1/4 of 600W into 16 Ohm), what a thump in my stomach, it was like BOOM and then I damped the note slightly and let it sustain and it just turned into the sweetest harmonic feedback driving through all the octaves ... what a pleasure live can be!!
Hmmmm, sounds like you have had sweet results from this. Like TomW I am wondering whether its worth the upgrade.
I would have to put G12T75's back in, sell 1960, buy new cab Bogner + fit my Sidewinders.
Bogner clone / similar specced cab (empty?)
Does recorded tone differ with your Tascam recorder?
Quote from: Will on September 01, 2008, 08:04:55 PM
I'll try some room and close recordings to compare the Heritage and the Bogner.
Good thing is I have a stereo amp, so I can connect one cab either side and fade left to right to compare them.
Did you do any clips in the end?
The wheels are in motion, just ordered an unloaded 4x12 :)
maverickf1jockey
On a related note and rather than start a new thread I just took delivery of a Hayden Peacemaker 4X12" cabinet.
I haven't put it on full blast but it sounds excellent from what I can tell (although I'm not yet a connoisseur in terms of larger cabs).
I have only two reservations about it:
1: The piping appears to be made of yellow translucent washing line, but only on close inspection. It actually looks surprisingly swish.
2: With my Tiny Terror on top my amp looks like David Byrne from Talking Heads. This is made all the more comical by the fact it is a light cream tolexed cabinet.
Overall I'd say it was worth a punt at the £120 asking price new.
I think that Hayden are trying to clear stock out of shops to make way for new models at the moment so I'd get them now if you need a big cab on the cheap.
I also think they are actively undercutting other manufacturers to get their product into the open market and escape the reputation that they had as Ashdown amps.
They also claim to have one of Martin's colleagues from Matamp working on the amp designs. Perhaps Martin could shed some light on it and his views on this designer.
martinw
Quote from: maverickf1jockey on September 29, 2008, 11:36:50 PM
Dave Green, formerly of Matamp, does indeed work for Hayden. Not much change, as most of the Ashdown guitar amps were Matamps in drag.
Other than that, no comment!  :wink:
Custom Built Amps:
www.mjwamps.com
ronin
Just double checking.  Does your 4x12 have the Vintage 30's in it?
Thanks!
Quote from: PhilKing on September 30, 2008, 05:05:29 PM
In Dave's own words wouldn't that be no f---ing comment  :shock:
Ha ha- certainly would!
