Author Topic: Pulling valves  (Read 5557 times)
  • Truly bad since 1972
Pulling valves
« on: September 04, 2008, 07:31:15 PM »
Have this 100pa monster head....is it possible to reduce power by pulling valves and if so do you also adjust ohmage of output(IE 4 valves 16ohm is 8ohm in 2)
Woogie
Re: Pulling valves
« Reply #1 on: September 04, 2008, 07:43:22 PM »
Would the ohmage even change? Cos the speakers are the same.
Re: Pulling valves
« Reply #2 on: September 04, 2008, 08:21:14 PM »
ohmage will change if you pull some valves even the though the speakers are the same
Re: Pulling valves
« Reply #3 on: September 04, 2008, 08:22:13 PM »
I thought that...but will it kill amp or change biasing
Re: Pulling valves
« Reply #4 on: September 04, 2008, 08:36:35 PM »
Of all people, I wasn't expecting Feline to use the "word" 'ohmage'...
Re: Pulling valves
« Reply #5 on: September 04, 2008, 08:37:17 PM »
*L*
Re: Pulling valves
« Reply #6 on: September 04, 2008, 08:42:14 PM »
I don't get it :?
Yeah, speakers take the load that the amp gives, half the power output, half the load the amp gives I think
Re: Pulling valves
« Reply #7 on: September 04, 2008, 10:56:09 PM »
Yeah - halve the output impedance setting
Oli
Re: Pulling valves
« Reply #8 on: September 04, 2008, 11:03:06 PM »
On one side of the transformer (the primary), you have the output section of the amplifier, and on the secondary coils, you have the speakers. Transformers work on a ratio system, so what happens on one side has to happen on the other- or else you end up with an imbalance, and mismatched impedance. By removing two of the valves from the power section, you halve the impedance, so you need to half the impedance on the speaker-side of things.
Re: Pulling valves
« Reply #9 on: September 05, 2008, 07:50:11 AM »
Yay, Baby Jesus no longer needs to cry :)
Roo
Re: Pulling valves
« Reply #10 on: September 05, 2008, 02:33:39 PM »
So 8ohm in 4valve(that I have set now on back) is now is 4ohm  when I remove 2 valves
Re: Pulling valves
« Reply #11 on: September 05, 2008, 09:58:18 PM »
I'm out of my comfort zone with all this valve stuff, but are we SURE that dropping valves changes "ohmage" (to quote Johathan)?
Doesn't it depend more on the output transformer?
I know ask because when John Cooper did work on my Orange and re-valved/biased it, he dropped 2 output valves, but the ohm setting remained the same.  I don't think that he did any other work.
Again, I don't know, but thems the facts, innit?
Mark.
the_bleeding
Re: Pulling valves
« Reply #12 on: September 06, 2008, 01:51:50 AM »
dont pull valves. Sure it reduces wattage but it does NOT reduce volume by any noticeable amount. 3db is a very small difference for the risk you take doing it. Also, when you pull them, it makes your amp sound like shite. Your amp was designed for 4 valves, pulling 2 will make it sound gross. I have a halfpower switch on my amp, it effectively shuts off 2 valves. I relabeled it the "suck" switch because thats what it does.
hamfist
Re: Pulling valves
« Reply #13 on: September 06, 2008, 07:45:55 AM »
dont pull valves. Sure it reduces wattage but it does NOT reduce volume by any noticeable amount. 3db is a very small difference for the risk you take doing it. Also, when you pull them, it makes your amp sound like shitee. Your amp was designed for 4 valves, pulling 2 will make it sound gross. I have a halfpower switch on my amp, it effectively shuts off 2 valves. I relabeled it the "suck" switch because thats what it does.
 This is a very common story to hear from people who have tried halving the number of output valves, although I admit I have not tried it myself.
Re: Pulling valves
« Reply #14 on: September 06, 2008, 09:18:29 AM »
Hmmm...  I can't say I agree.  My Orange sounds amazing with just 2 EL34s.  Maybe it depends on the amp?
Mark.
