Author Topic: Recommend me an amp  (Read 8985 times)
mikeluke
Re: Recommend me an amp
« Reply #15 on: September 16, 2008, 11:53:31 AM »
Building/following on this thread - one of our guitarists has just bought a Cornford C30 - lovely amp but only a single channel - £750 new. Got me thinking - what would you suggest for the following spec:
Combo
Around 25-40W
1 x 12 speaker
Must have two channels - footswitch
Good clean and a crunch channel that can handle 'classic rock - no high gain metal required.
Max budget is £1000 UK new
Let's see if there is anything out of the ordinary that gets suggested!!
Mike
Mules, Riff-Raff
Stevepage
« Reply #16 on: September 16, 2008, 12:08:22 PM »
Fender Hot Rod Deluxe for sure. Lovely amp and has everything you just listed except a 3rd channel
« Reply #17 on: September 16, 2008, 12:20:04 PM »
I alsolutely think that a valve preamp is your way to go and will give you the best results for the cash you have.  The 5150 power section is an absolute monster and stays clean at insanely high volumes which makes it a perfect power amp candidate.  Just plug a seperate preamp into the effects loop return and use the master volume.
You could pick up a Marshall JMP-1 on ebay for under £300 that will give you all the Marshall tones you could ever want.  If you can find one, the Marshall 9001 is the rack preamp version of the Silver Jubilee series amps and they usually only go for around £150
I would also point out the Johnathon (Feline) has Engl and Soldano preamps on ebay at the minute for £299 a pop, both absolute bargains.
I just feel that buying a complete new amp in your situation is false economy and won't get you what you want.  The power-amp section of the 5150 is as good as anything you will buy, so why not utilise it.
If you can stump up more cash, I would look at the new Rocktron ProphecyII preamp.  I'm seriously impressed by it and will have one in a couple of years once there are deals around on them.
« Reply #18 on: September 16, 2008, 01:06:50 PM »
Combo
Around 25-40W
1 x 12 speaker
Pushing the budget slightly, but your best option is a Blackstar Artisan 30.  Great amp and fulfills your spec if you use a Y-lead and an A/B switcher for channels.
mikeluke
« Reply #19 on: September 16, 2008, 03:50:40 PM »
Blackstar is cheating! (Lovely amp though) Y-splitter, A-B box.... to complicated for me!
Mules, Riff-Raff
sambo
« Reply #20 on: September 16, 2008, 03:53:34 PM »
I would say Cornford Carerra.
EDIT: Ah didn't notice you said your band mate has just bought a Cornford.
mikeluke
« Reply #21 on: September 16, 2008, 04:56:02 PM »
Carrera doesn't make the power requirements - you have to go up to the Hurricane which blows your budget!
Anyone tried an Orange Rocker?
Mules, Riff-Raff
sambo
« Reply #22 on: September 16, 2008, 05:29:16 PM »
Oops- yep just checked- only 5-8 watts!? Had no idea- tried one the other day and sounded brilliant, but was totally unaware it was such a low power rating. :oops:
