How bright and/or bassy are Cold Sweats?
Started by Twinfan, November 14, 2008, 11:34:01 PM
AdamB
Nolly has a CS in his blackmachine. He says it's basically a nailbomb but with fewer winds. He's got one with 2 rows of screws though because it used to be a warpig, so that probably increases the bass a bit
SG-X/Over wound Rebel Yell
Blue SG 61 Reissue/Cold Sweat
Egnater Mod 50
Matamp 4x12
Yamhammer
Quote from: Catalyst77 on November 15, 2008, 06:56:46 PMBut you cant go wrong with CS, it is a BK after all!
+1. Can't go wrong with any BKP  :)
Right, I've been having a long hard think about this today and I've decided I'm going to go for VHIIs instead.  I'm a bit nervous about ceramic pups, and the guitar in question has a lot of acoustic output so hot pickups might be too much.  I want a cleaner tone with good treble and not too much bass, so VHIIs seem to be the way to go.
Philly Q - I'll let you know how they turn out  ;)
Excellent!  Are you just going to take the plunge and buy a set, or test it out with your existing ones?
I'm going to buy another set with nickel covers  :)
Yamhammer
Great choice going for the VHIIs. Those are the one and only pickups I'd still try one day in a Les Paul...I guess they're going to kick some ass.
I hope so!  I've just emailed Tim et al to check it's a good choice for what I want....
mikey5
How do the Vh11 compare to the huge sound of the Mules??
If I remember rightly they're a bit cleaner and not as fat, but a touch hotter?
roland_rat
Sounds an intresting choice.  I will be very intrested to here how it works out. :shock:
I have a Cold Sweat in my Indie (alder) I think it sounds amazing for my Metal music. Even with other genres as I tend to flutter about the place. However I disagree with opinions on it's clean channel. I use my C-Warpig for cleans.
Right - info from Tim is in and without any prompting from me he says Riff Raffs or Cold Sweats   :?
I've got Riff Raffs in my SG already, so for the sake of something different I think I'm back on the original Cold Sweats plan!  I'll let you guys know how it works out...
Don't be scared by the ceramic and convince yourself out of it again!
I won't.  Something different is good.
Keep saying it.....
Something different is good, something different is good......
