Author Topic: Is there a 'boutique' Marshall Guv'nor type distortion pedal?  (Read 18497 times)
« on: November 20, 2008, 09:52:31 AM »
Pretty much as the title says really!
I've got an original Guv'nor on my pedalboard ( cheers sgmypod  ;) ) which is the best pedal I've found so far to do JCM800 type tones.  Unfortunately it's quite noisy, a bit thin and scooped sounding, and a bit transistor-y.  So I'm looking for something similar that fixes those problems.  I play into a clean JTM45 and other stomps I've tried are:
* Electro-Harmonix Metal Muff (a bit fuzzy, as you might expect!)
* MI Audio Crunch Box (bit too compressed sounding for me)
* ZVex Box of Rock (not enough gain, not tight enough)
* ZVex Box of Metal (a bit thin and fizzy sounding, annoying noise gate)
I'm a bit stumped as to what else I can try!  There are LOADS of plexi-type overdrive pedals but I can't find a good "Marshall heavy distortion" pedal.
Anyone got any other suggestions?  My Martamp Orion will have a heavy distortion channel when I get it, so I don't need any amp recommendations thanks!  I'm looking for something on my board for backup/flexibility.
Any ideas???
  • Truly bad since 1972
Re: Is there a 'boutique' Marshall Guv'nor type distortion pedal?
« Reply #1 on: November 20, 2008, 10:34:02 AM »
Isn't there a copy of the guv'nor out there..with the quietening mods and others to give more variance in tone.
Guessing want to keep original..original
« Reply #2 on: November 20, 2008, 10:42:50 AM »
I did a search, but couldn't find anything?
« Reply #3 on: November 20, 2008, 10:43:50 AM »
The award session JD10 has a hot-rodded-marshall vibe.
Dazza1004
« Reply #4 on: November 20, 2008, 10:52:32 AM »
I would suggest one of the Blackstars but I am pretty sure you've had one of those as well  :)
I have always wanted to try one of the Soldano Supercharger pedals, not sure if they are worth a look for you
« Reply #5 on: November 20, 2008, 10:56:29 AM »
What about the new guv'nor plus..supposed to be an uprated version...but is new marshall..and not tried one
« Reply #6 on: November 20, 2008, 10:58:43 AM »
And at mo using my orig Drivemaster for that kinda sound..
Elliot
« Reply #7 on: November 20, 2008, 11:02:56 AM »
Tech 21 British?  I have the Blonde and it goes from clean Twin to insane Bassman, so the British should do heavy marshall as well.
http://www.youtube.com/watch?v=9YKdiMcI2NU&feature=related
http://www.youtube.com/watch?v=FdZA33e4RZQ
http://www.tech21nyc.com/character_series.html#
« Last Edit: November 20, 2008, 11:05:02 AM by Elliot »
« Reply #8 on: November 20, 2008, 11:04:34 AM »
http://www.generalguitargadgets.com/index.php?option=com_content&task=view&id=99&Itemid=26..on here a kit to build a guv'nor with modern improvments..but doesn't say what other than a true bypass..but may be worth a look
hamfist
« Reply #9 on: November 20, 2008, 11:10:44 AM »
THe Lovepedal Purple Plexi 800 is a good bet at the moment, very much what you are looking for I think, Dave.
Also consider a BYOC Shredder pedal, (either as a kit, or ready built from http://axeandyoushallreceive.com/).
 I just got a BYOC Tube Screamer from "Axe and you shall receive", and it is top quality. The components are top notch, and I am very, very impressed by the low noise floor.
The Himmelstrutz Fetto is also an awesome, yet expensive, pedal that would suit you very nicely as well, IMHO.
« Reply #10 on: November 20, 2008, 11:13:11 AM »
BYOC stuff is very quiet..even when built by me
« Reply #11 on: November 20, 2008, 11:35:54 AM »
Thanks guys!  :)
To recap and comment:
* Blackstars - had the HT Dual, didn't like its colouring on my tone
* Soldano Supercharger - might have the same issue as the HT-Dual, more like a preamp when I only want a stomp
* GGG MDV - same as a Guv'nor tonally by the look of it, so no good
* BYOC Shredder - I've already got a Shredmaster, and it's a bit too smooth sounding for me
* Guv'nor Plus - reviews suggest it's cheap and pants
So that leaves:
Lovepedal Purple Plexi 800 - seems like a good option?
Himmelstrutz Fetto - £200 before I even post it, an unknown gamble?
« Reply #12 on: November 20, 2008, 11:41:16 AM »
or build one
« Reply #13 on: November 20, 2008, 12:03:05 PM »
I haven't a clue what to do to build one!
Dazza1004
« Reply #14 on: November 20, 2008, 01:24:08 PM »
plus you would have to build 2  :D
