Author Topic: Egnater Tourmaster  (Read 4890 times)
Simon D
Egnater Tourmaster
« on: December 04, 2008, 09:23:14 PM »
Does anyone have any experience with Egnater amps in general, or the Tourmaster in particular? I seem to remember Adam B buying an Egnater a while ago? I'm curious as to where you get them from, as there isn't a UK dealer/importer at the moment. If I were to buy one from, say a French website, would the plug and voltage be alright for the UK?
Apologies for all the  (probably quite daft) questions, but I'm quite taken with the idea of the Tourmaster - it might just be the amp solution I've been looking for.  :twisted:
Warpigs.
Re: Egnater Tourmaster
« Reply #1 on: December 04, 2008, 09:27:47 PM »
Adam does. He has an Egnater 50. Haven't seen him around though. Aren't European plugs different to UK?
Simon D
« Reply #2 on: December 04, 2008, 09:33:17 PM »
That's what I'm wondering about. Changing a plug is easy enough, assuming the voltage is ok, I think.
Warpigs.
« Reply #3 on: December 04, 2008, 10:11:47 PM »
Are they not standard kettle lead with a voltage switch on the back?
« Reply #4 on: December 04, 2008, 10:12:11 PM »
european voltage should be the same (or close enough). it's the plug which is the problem, but if you use a kettle lead with the correct value of fuse, you should be ok.
but check with someone who knows for sure, lol. :)
« Reply #5 on: December 04, 2008, 11:46:28 PM »
You may also need to check and maybe change the fuse value if it still has the USA value one as the current draw will be different to use in UK & Europe.
There have been some teething troubles with the Tourmaster series from what I have heard - random indidences but others have been blown away
I am getting one of their modular preamps in the next few weeks - been on order for a while
But Adam has the USA made Mod 50
Have you asked about these issues here on the Egnater Forum
http://www.rig-talk.com/forum/viewforum.php?f=26
Video clips here
http://www.youtube.com/watch?v=8izQL8R5CPU
AdamB
« Reply #6 on: December 05, 2008, 05:56:06 AM »
Yo!
Yeah i have an Egnater Mod 50! It's an amazing amp, but yeah, it's made by Bruce and Jeff in the USA, and costs quite a bit more than the tourmaster range, although they're still great amps :D
My Egnater has a voltage selector on the back, and you can can change the plug easily enough too. The best thing to do is post on the Egnater forum, ask if it has a voltage selector etc. Jeff will usually give you a answer pretty pronto, as with any other questions you might have
Get a Mod 50, or what Jonathan is getting, an M4!
SG-X/Over wound Rebel Yell
Blue SG 61 Reissue/Cold Sweat
Egnater Mod 50
Matamp 4x12
AdamB
« Reply #7 on: December 05, 2008, 07:38:04 PM »
Here's a video demo of the tourmaster too, http://uk.youtube.com/watch?v=L1TCO1Kcwnk&feature=related
Egnater Mod 50
Matamp 4x12
Simon D
« Reply #8 on: December 06, 2008, 10:58:15 AM »
Cheers for the info guys, I'll check out the Egnater forum and ask the guys about voltage.
Thanks, Si
Warpigs.
