Author Topic: few different questions  (Read 6976 times)
CJ
Re: few different questions
« Reply #15 on: January 10, 2009, 12:06:58 AM »
i'm going to order that gotoh floyd, but i need to make sure it is the correct size/dimensions. it gives me base plate width, post spacing, and string spacing. the base plate appears to be maybe a millimeter off, but i'm hoping its either measurement error or it won't make a difference. the post spacing, i'm not sure what this is... what do i measure? the spring spacing- i first measured E to e and it was 4 mm short of the given dimensions, but the i measured the outer edge to outer edge of the slots that the strings go in, and it appears to be right or within a mm.
