Author Topic: USA/Voltage converters.....  (Read 4868 times)
AdamB
« on: February 03, 2009, 01:59:17 PM »
If this is in the wrong section, i'm sorry.
What are the best/safest way to run an American amp in the UK?
I always see great american gear for sale, and although my bank balance says no, sometimes i just want them! You know how it is :D
SG-X/Over wound Rebel Yell
Blue SG 61 Reissue/Cold Sweat
Egnater Mod 50
Matamp 4x12
Spitfire
Re: USA/Voltage converters.....
« Reply #1 on: February 03, 2009, 02:01:36 PM »
get a step up transformer with a power rating high enough to run the amp..
when i had my American voltage mesa mk4.. i contacted mesa and asked them how much power the amp draws.. it was somehting like 900w.. so i got a 1kw step up power transformer.
Fender Telecaster
Jackson KV-4
Starfield SVA-1
ToneMonkey
« Reply #2 on: February 03, 2009, 02:03:44 PM »
Step down transformer is what you're after (220/110Volt).
Quick search found this:
http://www.euronetwork.co.uk/acatalog/Voltage_transformers.html
There's going to be some people on here who will be able to better advise things like how this will affect tone (which it probably will).
AdamB
« Reply #3 on: February 03, 2009, 02:23:45 PM »
Cheers for the link!
Can a power supply really affect tone?
Egnater Mod 50
Matamp 4x12
martinw
  • Building Amps in the Hills.
    • http://www.mjwamps.com
« Reply #4 on: February 03, 2009, 02:38:12 PM »
No.
You can get the transformers from Maplins.
Custom Built Amps:
www.mjwamps.com
AdamB
« Reply #5 on: February 03, 2009, 02:51:33 PM »
Egnater Mod 50
Matamp 4x12
Spitfire
« Reply #6 on: February 03, 2009, 03:00:52 PM »
yea stepdown thats what i ment lol.. damn im going mad thesedays.
Fender Telecaster
Jackson KV-4
Starfield SVA-1
martinw
« Reply #7 on: February 03, 2009, 03:39:32 PM »
I use one of these:
http://www.maplin.co.uk/Module.aspx?ModuleNo=13358
300va will be enough for a 100W amp. £39.99.
I've been using one for years.
Custom Built Amps:
www.mjwamps.com
AdamB
« Reply #8 on: February 03, 2009, 03:40:59 PM »
Nice one Martin, thanks :D
Egnater Mod 50
Matamp 4x12
jpfamps
    • http://www.jpfamps.com
« Reply #9 on: February 03, 2009, 04:07:54 PM »
Many modern amps have there mains transformers wound such that they can be wired for 120V or 240V operation, in which case any competent tech would be able to perform a conversion (thus saving the inconvenience and extraweight).
Another alternative is to buy a replacement export transformer and have this fitted. I've done this for Fender amps and it still works out cheaper than buying one in the UK (even with the charge for fitting).
Obviously if you convert to 240V operation you should reduce the mains fuse to about 1/2 the value for 120V operation.
Export transformers are usually larger as UK mains is 50 Hz rather than 60 Hz in the US (you need a larger iron core to avoid saturation).
If you do get an external transformer, the VA rating should be above the power consumption of the amplifier by a reasonable margin, say at the very least 25% more, although the bigger the better.
ToneMonkey
« Reply #10 on: February 03, 2009, 06:37:06 PM »
Check out the transformers I get to play with:
http://www.brushtransformers.com/product-listing/1005
Nolly
  • Global Moderator
« Reply #11 on: February 05, 2009, 12:25:11 AM »
Oh dear Adam, what's caught your eye now?  :lol:
AdamB
« Reply #12 on: February 05, 2009, 05:46:24 AM »
It was a limited edition VHT classic chrome fronted power amp! :D
It was $3000 and i don't need it what so ever, i was just thinking that if i did, would it be easy enough to get a voltage converter?
Always on the look out! haha!
Egnater Mod 50
Matamp 4x12
Nolly
  • Global Moderator
« Reply #13 on: February 05, 2009, 09:03:16 AM »
That's completely random mate! :lol:
Philosoful
« Reply #14 on: February 05, 2009, 01:15:46 PM »
I just got a voltage coverter for Amazon for my PQ-4 which has American socket thing, piece 'o cake!
