Quote from: Hybrid_Child on February 06, 2009, 06:57:45 PM
How is the Cold Sweat neck compared to Seymour Duncan '59?
I had the '59 before in the same guitar (a japanese les paul copy) I had the cold sweat neck and other models
the '59 was the shitetiest neck tone I ever had, imo
the '59 was totally mid scooped, lifeless, dull, hollow sounding, not enough volume to match any good bridge pickup
it was like using nylon strings in a $70 acoustic guitar
the cold sweat has a lot more volume and sustain, but still in low/medium output, thick lead tone, more mids than the '59 or gibson '57, but still very slightly mid scooped (it's not like a JB or something) with smooth highs and a very defined bass, without sounding hard
the smooth top gives the impression of it being a middy pickup, but it's not
it's definitely middier than gibson burstbuckers, duncan jazz and other similar output pickups, very even voiced, but still having a bit less mids than bass or highs
like a dimarzio paf pro or something(?)
I wouldn't pair it with a mid heavy ultra hot pickup like a c-pig or the painkiller, but it matches really well almost anything below that level
Opeth guys use several guitars, mostly PRS Custom 24 with duncan SH-10 or SH-12 or stock pickups (HFS/vintage bass)
the cold sweat bridge is a great substitute for the PRS HFS, that has close specs (big ceramic magnet, similar output and dc resistance)
but those duncans are medium hot alnico pups, paf voiced mids, but with a ton of high end bite and weak low end
very articulated pickups fore sure, alnico magnet, but they have almost the opposite voicing of a holy diver or nailbomb and aren't really punchy pups
the screamin demon sounds a lot like a smoother bill lawrence (bright, very defined, scooped, a bit thin)
I'm not too familar with the full shred, but it has a similar voicing, apparently with less top end
if you liked the painkiller, than the cold sweat is a great option for you
it's like a warmer version of it, like I said
you can ask for an overwound version of it if you want more chunk
something around 17.5k for more girth
