Author Topic: two baritone guitars, both with different woods. what pickups do they get?  (Read 9847 times)
nfe
Re: two baritone guitars, both with different woods. what pickups do they get?
« Reply #15 on: February 12, 2009, 11:29:50 PM »
Vic Deakins, if you´re Zimbloth, and i assume you are, i DID ask you, and you gave great advice, so i got what i needed from your side :)
i´m trying to get lots of angles on the choises, so i can get arguments for both sides.
and guys, no-one is being mean, we all just have different goals tone-wise :P
now, what i´m wondering is if the ceramic warpig would work for my purpose (looow tunings etc) in the alder, or if i should go for a slightly less low-mids-y pickup?
i hear people saying the cold sweats are perfect for the low-tuned guitars in basswood etc (that´s you, zimbloth :P), but the painkiller is tempting me. how different are the two, and what is the winning argument on the side of the cold sweat?
i think "Vic Deakins" has the right idea as far as my way of thinking goes. consider that meshugah plays 8 string guitars tuned to F, and play with super-ultra-hot pickups :P
I'm not 100% sure about this, but don't Meshuggah play clean and add the distortion afterwards? Can't remember where I got that idea, so it could be urban legend...
Roo
I don't know about that, but they don't play with a huge amount of gain anyway.
« Reply #16 on: February 13, 2009, 12:47:03 AM »
they record with PODs, so this is not really relevant
it's like reamping without amps  :lol:
MF_Kitten
« Reply #17 on: February 13, 2009, 10:26:48 AM »
they record directly into their line 6 Vetta II heads, but they recently changed to Axe-FX :)
but yeah, they get super-duper-clear and articulate tone on the lower strings, even when the guitars play alone (the bass adds alot of clarity). the reason they can do that with super-hot pickups is because it has a slightly scooped low-mid range, as well as a little dip in the higher bass register (100 hz, the boomy zone! :P), and then there´s lots of high mids and treble. after using an EQ pedal with lots of amps and guitars (some with ridiculously crummy pickups), i can honestly say that this is the recipe for a tight tone in ultra-low tunings.
let´s see if some more people will have suggestions :)
Axe Palace
    • The Axe Palace
« Reply #18 on: February 16, 2009, 09:17:46 AM »
Hey Vic,
I've just got back from holiday here, and I've not seen you about before, so welcome to the forum.
Much of what you say I agree with completely, thanks for the comments. Just a couple of points you've skimmed over. Firstly, the scale length undoubtedly has an impact on output level (and probably on perceived 'distortion', although I say probably, as this part of the statement is just conjecture). I agree that slamming the front end of the amp harder is often (almost always?) a great way of tightening up the sound of a tube amp; indeed, I'll be doing this with my Black Dog-loaded 26.5-28" multiscale baritone with 14-70 strings in A-E-A-D-F#-B tuning, as and when the Bloody Murder I ordered last May arrives.
However, you've basically got a bit carried away in your post, and essentially accused both WezV and me of not knowing what we're talking about. While I can't and won't speak for Wez, he's a lot more experienced than me with this sort of thing. Given that I do, contrary to your absolute statement, know from first-hand experience what I'm talking about from my own experimentation, a reasonable extrapolation puts the luthier of my most recent guitar in an equal or greater position of authority to provide his advice than me, too.
For my part, I'll admit that I could have phrased 'muddier and less defined bass' in perhaps more flattering terms, especially in view of the fact that none of the BKPs I know of (either first-hand or second-hand from my time on these forums/other BKP user friends) are in any really tangible way muddy or poorly defined. The way I put it could be misconstrued as absolute (at a stretch), but that was not my intention, and indeed I don't believe in absolutes at all when it comes to guitar tone.
My reasoning for suggesting lower output pickups is that the option to boost with a pedal in front of the amp leaves more dynamic range available for cleans by cutting the boost and cutting back on the volume. It's still very easy to achieve the desired slamming of the front end of the amp, even with lower output pickups, especially if you have a long scale length coupled with reasonably large strings. This isn't me as a person on a forum getting caught up in absolutes, this is me as a person with said setup saying what works well for me, and advising that this works in my case. Sure, your mileage may vary - of course it can and will from guitar to guitar, from player to player and so on!
The vast majority of your post was accurate, helpful and friendly. Perhaps if you respectfully disagreed rather than launching a (albeit muted) personal attack, your posts might not be quite so abrasive...
Roo
Hey Roo,
My long post was not meant to be anything personal and I'm sorry if you or anyone interpreted it that way. I'm glad you understand the majority of where I was coming from however. I just had observed over the months the same (in my view) short-sighted posts regarding 7-strings and baritones and it got on my nerves since I knew better.  I wasn't singling anyone out, I was just trying to say that the idea that you can't get clear, tight, musical response out of the low B (or A) with the high output BKPs is not true. It varies amp to amp, style to style, cabinet to cabinet, etc.
I know as well as any that low output pickups can yield great results w/ low tunings, as someone who has been tuning down to B (or lower) for 10 years I've experienced that first hand. However, I've also been through a wide array of amps, and with some the low B is enhanced with high output pickups while low-outputters can be detrimental in fact (too dry, peaky for the heavy stuff).
Again, my only point was, let's settle down with the absolutes. Every time someone asks a question about 7-string or baritone, instead of just cutting and paste Tim's stock recommendation, let's keep our minds open. All my guitars have Bare Knuckles, 6 7 and 8-strings, most of them have the high-output BKPs in them and sound amazing. This is because Tim's designs are so perfect that you can get the aggression and saturation while still having the dynamics, definition and organicness of a mid-gain pickup. And also because my VHT rig is voiced well for it. Certainly someone else's rig may respond to low/mid-output pickups instead, thats the point though, it all depends.
PS: Yes I don't post here much but I lurk often. I get 2207207429724 BKP questions/advice solicitations/order inquiries a day on other forums as it is, but I've been meaning to post here more too :)
THE AXE PALACE - PROUD TO BE THE #1 BKP DEALER WORLDWIDE - www.axepalace.com
« Reply #19 on: February 16, 2009, 10:27:24 AM »
vic, i think you are misinterpreting my posts
Quote
i think what you have observed is an alternative viewpoint,  rather than short sightedness or mis-information.  I dont think anyone has ever said that you cant get "clear, tight, musical response out of the low B (or A) with the high output BKPs"
i have aimed to pass on great advice i have received from tim in the hope it serves somebody else as well as it has for me.  I dont think that has ever been done with absolutes as you seem to be suggesting - but it is advice i will continue to pass on, as well as continuing my experimentation with scale lengths, tuning and different pickups whenever i get the chance.
Quote
indeed, keeping your mind open is a good thing.  I made a suggestion and i copied tim's response and some links to other threads to back it up. You seem to view this negatively but what i was doing was trying  to back up a recommendation with some kind of evidence (for what its worth) as i know its a recommendation that doesnt always sit straight with peoples expectations right away.  pointing to threads where it has been discussed was meant to be helpfull too
at the end of the day it does not bother me if someone takes my advice or not, it was never presented as an absolute as you keep suggesting but an opinion in a thread where somebody asked for opinions.
its good to have the alternative opinions and experience on this issue, and i must say you have my interest in high output pickups for a barry renewed
« Reply #20 on: February 16, 2009, 11:29:55 AM »
Hi Vic,
Indeed, it's a privileged position we find ourselves in: with such a good range of amazing quality pickups!
I think we're all agreed that absolutes are a waste of time in this business (well, speaking about BKPs at least), so I think we can lay that one to rest...
Roo
il˙ti
« Reply #21 on: February 17, 2009, 01:40:46 AM »
In Vic's defense, some of you did keep making recommendations for low output pickups after MF_Kitten clearly expressed he wasn't interested in that type of tone. That's what made it seem like, to me at least, you were disregarding his opinion and that of others who had good results with high output BKPs in low tunings.
Crawlers, Mule-7s
« Reply #22 on: February 17, 2009, 09:10:34 AM »
yes, and i did point out earlier how i can see my second post as being taken the wrong way
Quote
also, re-reading the thread i can see my second post may come over as bolschy.  the reason for posting the links was because i tried posting a search results page but it just came up as the search option - so i posted directly to the threads i was referring to instead
i dont agree that i ever disregarded anyones opinion, although this is the internet and 50% of whats written gets taken the wrong way ;)
anyway, i am aware i am being a grouchy bar-steward this week (for many reasons) so apologies if my opinions or the way i have phrased them has caused any issues
« Reply #23 on: February 17, 2009, 10:33:31 AM »
I was simply trying to re-phrase the point that my setup is aimed at very high gain, tight, low, articulate and punchy metal/hardcore brutality, which I am able to achieve with a low output pickup (I'm not getting sucked into absolutes again!!). An alternative view to the OP's but one which I felt, and still feel, is relevant and worthy of consideration!
Roo
Alex
« Reply #24 on: February 17, 2009, 11:03:11 PM »
EMGs work quite well with baritones, they are kind of low output and have a little preamplifier. That would work as an argument in favor of the Blackdogs I guess.
