Author Topic: BIGSBY Tremolos  (Read 14741 times)
mikey5
Re: BIGSBY Tremolos
« Reply #15 on: February 15, 2009, 03:08:18 PM »
Righteous I think I will go with the bigsby then thanks my friends you are all righteous.
BTW Obama is a socialist
ToneMonkey
Re: BIGSBY Tremolos
« Reply #16 on: February 15, 2009, 03:14:52 PM »
Thanks to all. Great information. Couple last questions here. I heard that heavier bridges and tailpieces can increase sustain by a few seconds even. Being that the Bigsby is a big peice of metal like that would it help at all?
Can do in theory, but beware of tone voodoo.  If you're building the axe yourself then the actual build quality of the axe will have much more of a difference.
Never used a bigsby myself, but they certainly look the nuts
 :D
Bob Johnson
Re: BIGSBY Tremolos
« Reply #17 on: February 16, 2009, 11:08:52 AM »
Here's a pic of a neat little tune-o-matic conversion that I do for folks who want a TOM with a Bigsby. It uses Jag/mustang legs bonded into a modified TOM; it is also a perfect cure for Jazzmaster bridge problems as well.
Regards,
Bob Johnson
Legra Guitars
Re: BIGSBY Tremolos
« Reply #18 on: February 16, 2009, 09:53:04 PM »
I'm being thick, but what does that do?  Does it let the bridge "float" as the trem's being used so it goes back into tune better?
Bob Johnson
Re: BIGSBY Tremolos
« Reply #19 on: February 17, 2009, 08:22:34 AM »
Yeah that's it. It lets the bridge pivot or float on the two pins that protrude from the legs. The pins are threaded so that you can adjust the bridge height with an Allen key down the centre of the leg just like a jazzmaster or jag/mustang. The bottom of the hole in the body inserts is conical to locate the pins centrally.
Regards,
Bob Johnson
Legra Guitars
Re: BIGSBY Tremolos
« Reply #20 on: February 17, 2009, 09:04:46 AM »
Thanks Bob, that's interesting.  I was thinking along the right lines anyway.  :)
mikey5
Re: BIGSBY Tremolos
« Reply #21 on: February 17, 2009, 09:52:56 PM »
So Its good to have both right Bigsby and TOM
Bob Johnson
Re: BIGSBY Tremolos
« Reply #22 on: February 18, 2009, 07:23:04 AM »
It's good to have a floating bridge with a Bigsby. The wound strings can find it difficult to slide over some bridges and the TOM can be one of them depending on which make/model it is.
Regards,
Bob Johnson
Legra Guitars
mikey5
Re: BIGSBY Tremolos
« Reply #23 on: February 19, 2009, 01:40:19 AM »
Hey would you guys mind sending me an example model
Bob Johnson
Re: BIGSBY Tremolos
« Reply #24 on: February 19, 2009, 11:10:40 AM »
Could you expand a little on that Mikey?
Regards,
Bob Johnson
Legra Guitars
Spitfire
Re: BIGSBY Tremolos
« Reply #25 on: February 19, 2009, 11:19:51 AM »
me too, i want a free guitar too!!
Fender Telecaster
Jackson KV-4
Starfield SVA-1
mikey5
Re: BIGSBY Tremolos
« Reply #26 on: February 21, 2009, 02:33:21 PM »
I mean an internet link to a model with the floating bridge not an actual peice of hardware sorry.
Mike
« Last Edit: February 21, 2009, 02:35:50 PM by mikey5 »
CaptainDesslock
Re: BIGSBY Tremolos
« Reply #27 on: February 21, 2009, 03:19:49 PM »
funny, where have I seen that guitar before? I'm sure it must be super badass :)
BIGSBY LOVE!!!!
Rise above the crowds
Wade through toxic clouds
Breach the outer sphere
The edge of all our fears
Re: BIGSBY Tremolos
« Reply #28 on: February 21, 2009, 03:26:04 PM »
Mike
I am not sure there is actually a production model. Old ABR1 bridges (ones on vibrato guitars) had a bevelled edge and the same with the thumb screws, thats the only other place I have heard of them.
Bob Johnson
Re: BIGSBY Tremolos
« Reply #29 on: February 21, 2009, 06:35:14 PM »
The bridge in the pic that I posted was made by me out of a TOM with it's base machined flat and height reduced. The bridge is then drilled to accept the legs from a Jazzmaster/Mustang/Jaguar bridge. I first did this to fix some problems on a Jazzmaster which has a notoriously cr@p bridge but have subsequently used the same idea on guitars where the trem is mounted separately to the bridge. The bridge swings back and forth as you operate the trem negating the need for the string to slide over the saddles. Will was right; some old Gibsons with Bigsby trems had curved tops to the saddles to help the strings to slide.
Regards,
Bob Johnson
Legra Guitars
