Pick-ups for melodic death metal.
Started by BL4CK_K1N6, February 26, 2009, 11:12:45 AM
#15
I'd pick the c-pig for brutal death metal, but the miracle man is just perfect for melodic death and modern metal in general
stuff like CoB, Soilwork, Carcass, Neaera, The Haunted, Blinded Colony, Sylosis, At The Gates comes out really naturally from it
and I think it will retain more clarity on 7 string tunings than a c-pig
you can here some awesome miracle man on a basswood ibanez clips here:
http://netmusicians.org/?section=id&value=1097
http://netmusicians.org/?section=id&value=2473
http://netmusicians.org/?section=id&value=2578
http://netmusicians.org/?section=id&value=2653
not your style or the appropriate amps for that, but still great  :D
I use a ceramic Warpig for melodic death metal. Or my view of melodic death metal that is. I have a cold sweat neck to complement it.
dheim
Quote from: BL4CK_K1N6 on February 27, 2009, 10:58:09 AM
Thanks for the answers!!
Most of you have suggested me the Miracle Man bridge... It is good also for leads and solos? Because if it's I change only the bridge pick-up...
i wouldn't do it... you'll be begging for a neck BKP then, and you'll have to work again on your guitar later... :)
too many? ;)
BL4CK_K1N6
Quote from: Eric Hellstyle on February 27, 2009, 05:54:50 PM
Nice site! Thanks!!
Quote from: dheim on February 27, 2009, 09:00:50 PM
What neck pick-up do you suggest me for leads and solos?
[url=http://www.myspace.com/livormetalmusic][size=10pt]Livor[/size][/url]
dheim
many would say cold sweat. it's a great neck pickup, but i tend to prefer nailbomb neck, because it has got more presence and mids... CS is a bit more scooped and warmer. both are great for leads (even if for dynamic distorted solos i generally prefer bridge pickups)... warpig neck is very very beautiful too, noone seems to ever mention it...i'd go for it in a calibrated set, though.
too many? ;)
Benkenove
Well, I will give you my "personal" thoughts...
I also play melodic death metal, and I've tried the Nailbombs (alnico set), Miracle man (set) and also the Painkiller bridge...
For my personal tastes, the PK didnt work at all... was too trebly with many highs - middle/highs... I had a bad time on stage when I change guitars from one with the MM to the PK... the sound changed a lot, and I had to start tweaking the amp on the fly... (bad moment).
I really think the MM are a great pickups for the style, very powerfull and great palm mutes, and it cuts really cool, nice compression... BUT I even think the Nailbomb is way better for the style... Way more... "melo-death"... more In flames/soilwork/darkTranquillity/ArchEnemy... at least, more for what I'm searching and for my guitas/amp/music/hands/ears.
I personally keep the MM in one guitar, and NB in other 3 guitars... (I'm waiting for a NB ceramic which I will put on an ESP explorer, and I think it will be really cool and thicker and tighter, I'll let you know).
But I think you cant go wrong with MM or NB... (but NB is godsent for melodeath).
Good luck and let us know when you get them... ;)
P.S. if you want to buy a set, Id go with a matched set, Iwoulnt mix, the MM and NB works perfectly theirself ;).
(Again, this is my personal taste, no more, no less... I guess there would be people who are not agree but well, just my 2 cents)
Ben Melero
JOTNAR
www.myspace.com/jotnarmyspace
NEW ENDING
www.myspace.com/newendingmetal
BL4CK_K1N6
Thanks at all for the answers!!
Other suggestions for neck pickup?
dheim
it strongly depends on the kind of neck sound you like best... nailbombs are sharper and middier, they sound almost like bridge pickups in terms of clarity (but of course they're undoubtably neck voiced), cold sweats are very, VERY smooth but even so note articulation is very good, holy divers are somewhere in between but have a very different voice frome the other two... more scooped than NB and sharper than CS... have you checked out my pickup shootout? they're all covered...
too many? ;)
BL4CK_K1N6
Quote from: dheim on March 03, 2009, 02:27:56 PM
A sound for leads and solos, a defined sound. I would hear the attack of the notes! I think that the neck Nailbomb can be good...
dheim
i think it is, for sure! i would go for a balanced NB set, for melodic death...
too many? ;)
BL4CK_K1N6
Quote from: dheim on March 03, 2009, 02:45:31 PM
The bridge pickup most suggested is Miracle Man :D
dheim
i haven't tried it (yet), but i agree with benkenove on the high opinion he has on the NB. i've got one set and i'm waiting for another... it's thick, tight but not too much, organic and defined but still not too much... and its frequencies are... well, right. at least for me.
too many? ;)
dheim
oh, and they're killers when palm-muted, even without the low grinding boom of warpigs...
too many? ;)
Quote from: MDV on February 28, 2009, 06:17:50 PM
Quote from: Eric Hellstyle on February 26, 2009, 03:44:03 PM
miracle man
The truth Darth Hellstyle speaks. The Miracle Man you must have.
when MDV and I about something agree, an unquestionable truth that shall be  :lol:
