Author Topic: Questions about the Blackstar HT-5  (Read 13788 times)
d1dsj
Re: Questions about the Blackstar HT-5
« Reply #30 on: March 03, 2009, 06:29:21 PM »
Cool.... hope it all works out for you, still don't think you can go wrong for that sort of cash! :)
« Reply #31 on: March 03, 2009, 06:53:08 PM »
Make sure you warm it up a bit longer than your other amps when you put it on standby.
I'm not sure how true it is, but the guys in Sounds Great said that they take a bit more warming up. Something to do with having push-pull AB something or other using just one valve. (means nothing to me)
Hope you like it
sounds odd to me... i would have thought all tubes of the same type are going to warm to the same point, over a varying amount a time. and the heater in the tubes should be desighned to apply a certain amount of current to the heating element and from that you can work out the time taken for the element to heat the tube at the average room temperature.
i wouldnt have thought class a or class a/b operation would relate in any way to how long it takes your tubes to heat up. maybe it does.
« Last Edit: March 03, 2009, 06:58:07 PM by Dmoney »
SG Thrasher
« Reply #32 on: March 03, 2009, 06:53:40 PM »
http://profile.ultimate-guitar.com/SG+thrasher/music/ I've got some clips of mine with my Nailbombed SG here, click on "Show track info" for details of OD settings etc.
Laney, Charvel and BKP
Black covered Nailbomb that I want to trade for a Warpig/Riff Raff, PM me
Dreichlift
« Reply #33 on: March 03, 2009, 08:40:12 PM »
Hope you like it
There's some sort of built in protection that stops the amp operating if you turn it on too quickly, it only takes a minute or two though and just makes sure the amp is at full operating efficiency before you start trying to melt the paint of your bedroom wall  :D
I admit when I first got it I turned it on and thought I'd got a dud for a few seconds.
« Reply #34 on: March 03, 2009, 08:41:38 PM »
ah right! thats kind of clever. still has nothing to do with the class of operation.
Matt77
« Reply #35 on: March 03, 2009, 10:15:37 PM »
I know nothing about class  :D
