Author Topic: help with my amp  (Read 2309 times)
Gizmo
help with my amp
« on: March 03, 2009, 04:14:34 PM »
made a massive error. my new amp was left on standby for days and i didnt realise. I just tried playing it and its lost its volume and the reverb sounds cavenous even when its on 1%. i think i might have screwed it up. could anyone advise. its a cornford carrera. help :(
Re: help with my amp
« Reply #1 on: March 03, 2009, 05:11:04 PM »
Did you turn standby off when you tried to play? :P
Well more seriously, I have also done the same with my Marshall, and found no ill effects. I have done that more times than its worth remembering
« Reply #2 on: March 03, 2009, 05:12:02 PM »
might be a tube issue. all thats powered when the stand by is on is the heater circuit for the tubes?
am i right?
« Last Edit: March 03, 2009, 05:15:35 PM by Dmoney »
« Reply #3 on: March 03, 2009, 05:14:34 PM »
Normally it should be no problem. Standby should not have that kind of bad impact. I would assume the amp wasn't particularly hot when you discovered it, right?
Probably a coincidence. If it remains after cooling down, you could swap tubes to check if you have some lying around, or bring it to a tech.
Gizmo
« Reply #4 on: March 03, 2009, 06:11:51 PM »
its ok. panic over. just left it off for a few hours and let it cool down. should be ok. thanks
« Reply #5 on: March 03, 2009, 08:03:00 PM »
sweet, glad to hear that it's ok now :)
