How to brighten the sound of my Gibson Explorer (w/ Painkillers)
Started by Ivan, April 09, 2009, 03:47:09 PM
I had the same problem with my Explorer when settling on a st of pickups for it - all too bassy.  This won't help you, but I couldn't find a set of pickups that worked in mine and ended up with EMGs.
For the most drastic change in tone, I'd try these in the following order...
* change to 500k pots (if they're 300k).  If they're already 500k, get 1M - can always put a resistor across the pot to bring it down to 750k for less brightness.
* disconnect the tone pot completely
* aluminium tailpiece
I'd use the old 50s Gibson style pickup wiring anyway as it sounds subjectively better to my ears - louder, crisp and more open like a blanket has been removed from over your tone.
Quote from: MDV on April 10, 2009, 02:59:32 PM
Oh, it gives quite a bit of control, no doubt, its why I use it, but one of its main strengths is you can add bass, and if theres too much to begin with then single screw is all you need.
+1
Double screw pole will make it bassier
I find also that with the single screw pole you  get the opportunity to make it brighter by raising  poles
Aluminium tailpiece is a great idea
and
Fit an Earvana nut!
As well as  making things more in tune , you get a noticeable amount more clarity which you may percieve as brightness
Quote from: FELINEGUITARS on April 11, 2009, 03:32:40 PM
funny, but i never thought of doing that on a SSP pickup until this thread!! nice tip
