LTD EC-1000 pickup suggestions
Started by schantist, April 17, 2009, 08:06:01 PM
the prince of shred
i beleive mm meats ur description there ....(but idk much...)
n a neck well kinda sounds like coldsweat but  :roll: holy diver??
someone??
#16
did you ever try a booster with the diver?
that is the key to get awesome metal tones with it
it was wonderful with the wylde overdrive I had (output maxed, drive zero, tone 6)
it gave that metal edge and extra sustain
just take some gain out of the amp
it surely gets as metal as my guitar did with the emg 85, but sounding like a guitar not like a synth  :lol:
schantist
Quote from: Eric Hellstyle on April 19, 2009, 10:55:36 PM
Never tried actually, never heard 'bout somebody boosting an Engl neither...
but the HD's gone anyways, so it's my +1 take on BKPs
Quote from: schantist on April 20, 2009, 11:21:02 AM
people don't boost amps
people boost guitars :good:
schantist
#19
Strange, I always thought that a booster pushes the amp's preamp section a little harder to tidy up your tone...
I wouldnt bother boosting a powerball.
It doesnt like it.
Its already got what boosts give - clarity, top end, tightness.
schantist
Quote from: MDV on April 20, 2009, 05:52:28 PM
Very true...
MVM
Quote from: schantist on April 20, 2009, 05:55:05 PM
Very true...
now you're missing the point
you boost the pickups signal, not the amp
QuoteHD was too tame and loose for rhythm stuff and the CS was great for fast solo stuff still sometimes too "cold" to get the singing leads I want
where is your tightness now?  PDT_045
my bandmate has a fireball based 100w amp
it is one of the tightest and definitely the gainiest amp I've heard
it does work well with his miracle man unboosted, and it works really well boosted too
but the holy diver is no near as powerful, tight, focused or aggressive as the miracle man
a boost really makes a LOT of difference with that pickup through any amp I've played
that's where it truly shines
as I said, you boost the pickups signal and response, not the amp
so if you didn't like it before trying it, you still didn't try it at its best
I have a heavily modded Framus Cobra and a Peavey Rockmaster
both are tight as frak, and the holy diver always worked WAY better boosted
you can get all the things you're missing about the EMG 85, but with real tone
ps: I'm Lord Hellstyle using my friends account at work (don't remember my own password :lol:)
Quote from: MVM on April 20, 2009, 06:15:55 PM
Very true...
Thats a fireball, not a powerball.
Powerballs are tighter and more in-your-face to begin with.
They DO like EQs in the loop. You can tighten the hell out of a sound like that.
schantist
As I said, the HD is gone...
Maybe mine was just messed up (I know I'm being blasphemous right now :D), here's the thread containing the review from the dude who bought my HD/CS set:
http://bareknucklepickups.co.uk/forum/index.php?topic=16484.0
MVM
#25
Quote from: MDV on April 20, 2009, 06:22:44 PM
it's not a fireball
its preamp section is based on the fireball (only 2 channels, I think)
what makes the powerball tighter is the larger transformers and higher power
my friends amp has a SLO100 based power amp and it's the punchiest amp I've heard live, along with the framus cobra
and seriously... if it was any more in your face than it already is, it would be used for demolition, not for music  :lol:
never heard any ENGL that sounded as tight and punchy as his amp
the fact is that the holy diver works better with a boost, at least for metal
that's almost obligatory
Quite contrary to my experience, mate. With some amps its night and day (uber, 5150, jcm800 etc), some not so much. The PB, hardly at all.
Till someone else thats boosted a powerball (and had good results) comes along I aint budging on this ;)
MVM
Quote from: MDV on April 20, 2009, 07:29:50 PM
I'll repeat
you don't boost the amp, you boost the pickup signal
some pickups will barely change (very subtle difference with the miracle man, for example)
the holy diver has a fat voicing, but not really a strong output
there's no logic in saying "oh my pickup sounds weak, cold and loose" and then"oh my amp doesn't need a boost, cause it's tight and hi gain" :lol:
Rubbish.
Same guitar, same pickups, same cab, same day, same room, same temperature, same humidity, same 808 into an uber made the uber sound awesome (instead of loose and dark), and a deliverance sound livelier and less dry, and did little to nothing to the PB.
MVM
#29
and it was a holy diver, right?    :shock:
i'm not discussing if amps react different to boosters
that's obvious
what i'm talking about is how the holy diver changes, no matter what amp
peaveys and engls are way less responsive to boosters, but they do change the tone, specially if the pickup is not really hot or tight by itself
he said that the pickup didn't sound as tight as he wanted through that specific amp and others did
so if he didn't try a booster with THAT pickup in that same amp, he can't assume that it won't make any difference because "powerballs are tight and boosters do nothing for them"
some common combinations may sound like shiteeeee, while others not-that-logical combinations can be great (like a miracle man on maple body or mid heavy 5150s through ultra middy heavy speakers)
but you can't make solid assumptions without trying it in at least close situations
I always thought that a holy diver would be the greatest thing in an SG (I should have listened to our Master), and it didn't sound good
sounded weak and muffled and dark
and it didn't make any sense to me, since I had it in two fat les pauls, and one of them had exactly the same wood grain/resonance/voicing/tone of the SG and was a way fatter and darker sounding guitar (plus a imbuya top that darkens everything a lot), and the diver sounded AWESOME in that les paul
maybe the extra wood "pushed" the pickup harder or something
I never could understand that, but that's a fact
if Tim says that something might not work well, is not because he can calculate all the factors and results, but because he obviously tried it before
it's like someone wrote some kind of gospel on guitar forums and most people just repeat stuff like "VHT and Mesa Mark amps are tighter than anything" and "Bogners are built like a tank and Framus are built like shiteeee with cheap parts", "Diezels are tight and hi fi", "Triple XXXs are not even close to the JSX", "death magnetic tone is great cause its got Diezels and Diezels are awesome and I can get exactly the some tone through mine", and "Marshalls can't do metal" without any kind of related experience
and when they actually try them, they have their minds already so made up, that their ears stop working or something
here in brazil, for example, it's hard to convince anyone that there are better amps than Rectos, even if you prove it to them, cause they think that a "Mesa is a Mesa" and nothing can be better than that
lol gotta work, c ya
