Author Topic: Wiring trouble, please help  (Read 10668 times)
Re: Wiring trouble, please help
« Reply #15 on: May 08, 2009, 09:32:12 PM »
Remember that solder flows towards heat!
But it follows gravity too!  :wink:   I hate it when you have a nice little "film" of solder over the hole in a pot lug, then you melt it again and it starts draining away down the lug - probably, I guess, because there's too much solder.
  • Brokeback is back
« Reply #16 on: May 09, 2009, 01:50:11 PM »
Thanks for all the advice. It's just so nice that you're taking time to help!
I'll try de- and resoldering the wires on the pot and hopefuly this will cure my problem. If it doesn't I'll try one of the old pots and see if it makes a difference.
Keven
« Reply #17 on: May 09, 2009, 02:18:57 PM »
+1 on filing the back of a pot. most good pots don't need that, but cheaper electronics oriented pots (.50c a piece..) require you to expose the metal. if the back is of a greenish bronze color, it's got a little covering that needs to be scratched off..
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #18 on: May 09, 2009, 03:34:21 PM »
Also worth noting is that most pots don't go completely to zero, in fact CTS make a "custom" pot which does go to zero but it costs a bit more than their usual range.
I see a rainbow rising
Look there on the horizon
And I'm coming home
