Pushbutton in pot .. does it exist?
Started by m0jo, May 09, 2009, 11:25:27 PM
CaptainDesslock
Quote from: m0jo on May 11, 2009, 09:53:10 PM
Quote from: indysmith on May 10, 2009, 11:31:41 AM
Quote from: WezV on May 10, 2009, 10:43:34 AM
fenders s1 switch is a push button on the volume knob, must be a way to wire that as a kill switch... you are stuck with fender knobs though
http://www.fender.com/products/s1/
But I think it's still a push/push SWITCH rather than a button...
Yes it is a push-push switch because it stays "down" after being pressed.
Plus no way in hell I'm going to put a strat knob on my Iba S  :lol:
Quote from: CaptainDesslock on May 10, 2009, 03:07:28 AM
You could give Legra Guitars a hollar and ask if they could make it for you, they deal with weird electronics all the time! http://www.legraguitars.co.uk
Yes but actually constructing a potmeter?
I'm getting around to e-mailing OMEG about building me a potmeter in a minute.
If they are willing, are there any other takers? (seeing as how 10 will be considerably cheaper than 3:))
Dude, I don't work there, I can't answer for them, but they are a quality shop who deal in guitar electronics as well.  Their main team consists of an electronic engineer and a mechanical engineer, which is why I recommend them for weird stuff like that.
Rise above the crowds
Wade through toxic clouds
Breach the outer sphere
The edge of all our fears
m0jo
Quote from: CaptainDesslock on May 12, 2009, 05:11:51 AM
Sorry, I realise I sounded somewhat.. rude. I simply meant that weird electronics basically is wiring the components in a particular (weird) way, this is really about constructing a component so I didn't  think they would be capable of doing that.
Depending on the reaction from Omeg I will give them a shout though. :D
MXG custom '60s fiesta red strat
Ibanez S470DXQM
-->shiteload of pedals-->
Laney VC100
CaptainDesslock
Quote from: m0jo on May 12, 2009, 04:53:29 PM
erry my bad, I didn't mean to sound like an ass either, but yeah if your first source doesn't work they might have a decent shot
m0jo
Quote from: CaptainDesslock on May 12, 2009, 10:29:40 PM
No problemo!  :huge:  I'm waiting for a reply ;)
Ibanez S470DXQM
Laney VC100
Today I read the Frankfurt review of current Guitarist, AND I COULDN'T BELIEVE MY EYES!!!!!
Page 74 - Shadow
"....Not neglecting electrics, there's a 500K log Kill Pot (approx. 20GBP) with push/push action for those machine-gun effects."
Ha! They thought of you before you did! And it's even a guitar stuff maker. So go, call Shadow, get one, and post clips and pics!!!
m0jo
Quote from: hunter on May 22, 2009, 04:41:40 PM
Here is info, the part code will be SH-124:
http://www.shadow-electronics.com/viewart.html?id=217&lang_id=1?lang_id=1
Now I am getting interested :O)
Wow that's great!! :D :D :D I don't really care who thought of it.. as long as it's there haha! :D
Thanks for the heads up!
Sorry I forgot to post back on the other source, but they could only make it with plastic surround and I'd need a convertor for the shaft etc etc.
So, I'll have to wait before I can get it around here in Holland. Shadow is based in Germany though so that shouldn't take that long :D But I do have to whine: the price, 20  GBP ?? That seems kind of high for just a pot+switch .. :(
Ibanez S470DXQM
Laney VC100
the_bleeding
fender has metal push/push knobs as well. My friend has one on his tele to go out of phase.
Quote from: the_bleeding on May 27, 2009, 07:42:40 PM
Dude, this is a momentary switcher, what you talk about is a normal push/push pot that switches between two states permanently. This one only holds pos2 (kill) for as long as you touch it.
m0jo
I accidentally found this image via a google-search:
It doesn't look as I expected. But it does look like they engineered it differently than the fragile push-push switches :)
Ibanez S470DXQM
Laney VC100
I guess the 2 connections on the black baseplate are for the killswitch.
If you connect main out hot and ground here, you're done!
ToneMonkey
My initial thoughts were to use a push/pull pot and put a spring under the knob to force it back upwards.  That way you would just have to push it down to break the circuit and it would spring back automatically.
Not really thought about it much more than that though, but it may be worth a little experiment.
Hope it helps.
m0jo
#27
Quote from: ToneMonkey on June 10, 2009, 11:48:29 AM
Hope it helps.
Well since Shadow is producing it, I'll just use that. I think putting a spring below a push-pull will make the knop too heavy to use fastly. But removing the latching mechanism of a push-push pot was my first thought.
Quote from: hunter on June 10, 2009, 11:12:01 AM
Yes that seems logical, from experience with push-pull and push-push pots I expected a DPDT switch.. of course a switch specially for killing would just have 2 poles, connecting and disconnecting them.
Ibanez S470DXQM
Laney VC100
Shadow make a killpot (SH124)
I am hoping to get some in stock soonish
Strangely enough I used to work for Shadow in 1989.......
