Started by _tom_, May 17, 2009, 10:29:16 AM
Quote from: camf on May 27, 2009, 06:58:11 PMInstead of boosting, have you thought of possibly using the pedal to reduce overall volume for chord work and then turn it off for lead... might keep the white noise down. Just a thought, I was going to try exactly that when I get a GE7.
Quote from: hunter on May 27, 2009, 10:07:52 PMQuote from: camf on May 27, 2009, 06:58:11 PMInstead of boosting, have you thought of possibly using the pedal to reduce overall volume for chord work and then turn it off for lead... might keep the white noise down. Just a thought, I was going to try exactly that when I get a GE7. +1If it's on 10, the boost will likely not make it any louder but just make it flabby and fart out. I'd rather set it for lead and then adjust for rhythm with the pedal.However, I'd just try both variants.
Quote from: hunter on May 28, 2009, 07:22:54 AMHave you tried slaving the Blackstar with the Laney?Or what about a W/D rig? I'd say that would be smoooove 8)
Quote from: _tom_ on May 28, 2009, 09:00:21 PMQuote from: hunter on May 28, 2009, 07:22:54 AMHave you tried slaving the Blackstar with the Laney?Or what about a W/D rig? I'd say that would be smoooove 8)What exactly is a wet/dry rig?
