Author Topic: When the missus is out ...  (Read 12135 times)
  • Truly bad since 1972
Re: When the missus is out ...
« Reply #30 on: May 20, 2009, 07:46:57 PM »
I was expecting copious amounts of Belgian White Beer, Mmmm!!!  :D
Nice pad though, bet it's a nice room for cranking some riffage out.
according to some rubbish on the BBC news ages ago, messy places are better for creativity, Hunter you need to make a mess first!!! knock the plant over in some guitar riffing rage!
Damn I must be able to write full symphonies if that is the case
JDC
« Reply #31 on: May 21, 2009, 01:40:52 AM »
erm hunter.... I thought the axe-fx only had 2 inputs?!!!
Nope, 4 (or 2 stereo if you want, but you can use the 4 separately). The stereo FX return has a level pot for in and out and can be used as ins.
You only have two input gain controls for the pairs though. So in our case, I had to adjust the gain for both guitars as a compromise.
ah so that's why there are 4 lines of blocks in the software editor!!! can you output the instruments separately as well?
« Reply #32 on: May 21, 2009, 06:34:34 AM »
Not sure if that's the reason for the 4 lines, it's probably more display/processor power reasons I presume. Bear in mind that many patches for 1 guitar can easily use 2,3 rows, for running multiple amps in parallel etc.
Axe has even more outs than ins because apart from the Out 1 and 2 (each in Stereo, so 4 outs), there is also the digital output.
JDC
« Reply #33 on: May 21, 2009, 08:10:51 PM »
you can only use 2 amps per patch right?
« Reply #34 on: May 21, 2009, 08:20:55 PM »
Yes, don't really think you'd need more. 95% of the time I am using one amp only.
