What's a ballsier alternative to Mules?
Started by Ivan, June 09, 2009, 11:24:22 AM
bewithdennis
Quote from: hunter on June 11, 2009, 03:17:56 PM
Quote from: bewithdennis on June 11, 2009, 02:56:01 PM
a liitle moore Billy f Gibbons
what now, Moore or Gibbons?
:O)
i think i meant more....
damn these fingers
8)
your title describes the Abraxas bridge to a tee - ballsier Mule.
the Abraxas neck is full on vintage though - very clear, but roll back the tone and it gets fatter.  ideally I'd like a fatter neck pickup, but you could always use a Mule or Crawler neck to match up with the Axraxas bridge.
The Emerald would also fit the bill nicely for a beefier Mule type response
Quote from: HEAVIER THAN HELL on June 11, 2009, 11:22:14 PM
Would you say the Abraxas neck is less fat than the Mule?  That surprises me.
I liked the Abraxas neck better than the Crawler, but I thought the Mule would be a tad brighter and less hot.
Quote from: Philly Q on June 11, 2009, 11:33:43 PM
The neck pickup is 6.9k which explains why it's quite bright.  My Mule neck pickup is 7.4k which is just right.  I think they're both AIV too, the Mule certainly is.
When I ordered my Mule neck pickup, I told Tim that I can find PAF neck pickups a little weak.  He explained that the Crawler neck pickup was a slightly hotter Mule (like 500ohms hotter) and that I might like that instead - thats what my Mule neck pickup is.
I might get the Abraxas neck humbucker rewound a bit hotter, or just sell it - would match better with a Mule or Stormy Monday bridge pickup.
The Abraxas bridge otoh is just perfect - everything you'd want out of a pickup with a PAF tone, but with enough weight to make the notes sing.
Weird, I'm pretty sure my Abraxas neck was 7.3k.  :?   I didn't really find it bright, but it did have a bit more "presence" than some PAF types, if I remember correctly.  And you're right, they're both AIV.
Maybe it's another of those cases where Tim has refined the specs?
I think I'll probably still go for a calibrated set (if I get them).  They're for a McCarty Korina so it's going to sound pretty sweet and warm anyway.
Dr. Vic
#21
The "average" DC value Tim gave me for the neck position (All AIV powered) are :
Mu : 7.3 K
Ab : 7.4 K
Cr : 7.6 K
BK says the pickups are "Wound, made and played the traditional way --- by hand !" 8)...with an indicative DC resistance. But it's true that an Ab (D.C. 6.9K) weaker than a Mu surprises me too...  :?
The only (important) clue I have to compare the CR and AB neck is what Tim said about them :
"Abraxas and Crawlers are very similar : fat, warm and singing. The Abraxas neck is just a little sweeter, the Crawler neck sounded slightly tougher/more aggressive. the Crawler is a little hotter than Abraxas although both are AIV powered. The Crawler neck takes the neck Mule tone to a much hotter level-DC7.6K Alnico IV."   8) 8)
but I'd be very interested to hear what works for you with the AB neck which didn't worked with the Cr neck ?
And congrat' for the PRS Mc Carty : one of a kind beauty ! Always been curious to know how to the korina sound, compared to mahogany... I know it's off topic but if you can says very few short words on that it would be great !
Quote from: Dr. Vic on June 12, 2009, 03:39:20 PM
Well, I think when I got the Crawlers I used pretty much exactly the same words Tim used there  :lol: : "The Abraxas neck is just a little sweeter, the Crawler neck sounded slightly tougher/more aggressive".
I was expecting them to sound almost identical, but in fact the difference was quite noticeable.  Whenever I try to describe the Crawler bridge, I always say it sounds aggressive and growly.   And that also extends to the neck model, to some extent.  I like a very warm, singing neck sound and the Abraxas was closer to that.
Of course they were in different guitars (both LPs, but one without a maple top), so that's part of the difference too.
It's hard to describe, it is basically similar to mahogany, but somehow it's both brighter and warmer.  The tone is really fat, lots of mids, but it also has "presence".  On a mahogany guitar, the high notes can sometimes sound a bit thin... with the korina, they sound bright but there seems to be more underlying depth.   It's like mahogany with all the tone controls turned up!  :)
Of course it's a PRS, and they always seem to use good resonant timbers, I haven't tried any other korina guitars to compare.
Dr. Vic
That's one-of-a-kind input Philly ! Thanks for your tips!
As Tim said the CR and AB neck are similar, I was thinking the difference was subbtle, not that noticeable. But as you said it may has a lot to do with the guitar too...
Anyway, my guess is that the Abraxas is certainly going to have more and more success in the near future...   8)
