Recommendation: replacement for EMG 81
Started by RyM, June 20, 2009, 08:54:14 AM
Dr. Vic
Quote from: RyM on June 21, 2009, 08:49:10 AM
I'll listen to all those clips, to get an idea of what a are we talking about... is there any "myth topic" talking about the differences between each BKP?
I am afraid not.  :(
Tim (BKP's Guru) doesn't even put the B/M/T diagrams on the description sheets of the pickups (like duncan does for instance) because he explains that scoring pickups like that wouldn't be an objective way to understand how they will sound in your guitar, because BKP are VERY sensitive to the guitar, which sums up why the myth topic you are looking for doesn't exist. (or I never saw it)
The only one thing you can do is having a look to the first sticky thread of this section where Tim explains all the differences between the magnet types. Indeed I think you have to decide first if you want :
- a replacement of your EMG for "something close in tightness and power but better" (in that case go for a ceramic) or
- to experiment something MORE different (in that case go for an Alnico V)
The Alnico Magnet is also called the musical magnet (as obviously opposed to the ceramic magnet). And as you said you wanted "musical over brutal" I still think an alnico will be better for you, especially with that kind of amp.
Nailbomb was suggested as a versatile pickup going from heavy metal to blues.
The Crawler also suggested here does it reverse way from blues to heavy metal. (in a nutshell)
But the more I think of it the more I believe the hot vintage section suggested before can be a solid choice as well (you'll find here the VHII your friend suggested   :))
...And also look at the Riff Raff ! Sorry another one that hasn't been mentioned yet  :lol:
ANY of these pickups will make you experiment something really different from you EMG81... and keep in mind the low output pickups are more dynamic and clearer (which means they expose your playing a lot more).
So Good luck !  :good:
HairyChris
OK, I have Cold Sweats in a PRS (mahogany + maple, rosewood neck). They can do pretty much everything. Not as crushing as some of the other models but yeah... rock, metal they're great... Clean up well for a ceramic. They go up to thrash if you want to take them there. Tim recommended them to me as a replacement for the VB/HFS set, which are modern rock voiced.
Um, Miracle Man I find much tighter. Not great if you want to loosen up a bit but as you play 81s there is some similarity in overall vibe. Way more expressive though.
The Warpigs are very good fun, but probably too much. Ceramic is absolutely brutal, the Alnico has a warmth & fatness to it but is massively saturated & compressed over about 50% volume.
I've only played my guitars through the amp so can't give too many other recommendations. :-)
I'd say Cold Sweat out of what I've played. Although they can do everything they sound great doing it. Their clarity is incredible too. Be prepared to notice your mistakes!
Quote from: RyM on June 22, 2009, 08:48:52 PM
Thanks to everyone for your replies!!! it's a pleasure to read you all.
So Chris, you are the man i was looking for!!! an Einstein owner with BKPs!!
I'm with MDV on what's he saying, the Einstein maybe could drive a vintage pickup to get high-gain sounds, but you have the answer on this, does it remaing "too vintage" or can it reach to metal? or do you think that the Cold Sweats could be the best choice?
Thanks again guys!!!
I'm going to recapitulate my crawlers call.
I have black dogs which I run through a Peavey 5150. They go ultra, ultra brootalz without difficulty. Given that you want something versatile, and that you have an Einstein (loads of gain on tap), you will be able to go as heavy as you like with pretty much anything from the VIntage-Hot range all the way up to the top-output contemporaries. What you get from a lower output pickup is the versatility you're asking for, crystal clear, warm cleans, all the way up (with your amp) to bone-crushing brootalz.
Roo
